Chris_924s's Avatar
headlights drooping....
I re-adjusted my headlights about 4 months ago- but now that darkness is at 4 PM, I noticed my headlights are beginning to droop.. Tonight the buckets actually went so far down as to kick the motor on and cycle the headlights completely back up.
any ideas?
TENSION YOUR SOCKS!
88 924S Guards/ Black ~ 10 years as a Daily Driver and STILL SMILING!
87 NA Diamond Blue Metallic ~ Gone
Old 10-27-2003, 04:24 PM
Let's go shooting.
Dark Skies's Avatar
Did you remove the actuating arms at all? I did this once and the headlamps would pop up to their usual position and then immediately slip down by about a half an inch. Turns out that I'd got the splines slightly out and the mechanism would over-cycle.
1983 944 Lux (manual) 2.5 litre 8 valve na and no pas
1991 944 (automatic) 2.7 litre 16 valve na and pas
"I have only five words for you: From my cold, dead hands."
Old 10-27-2003, 04:37 PM
Chris_924s's Avatar
Nope- just started. Headlights will start OK in correct position, then drop lower into buckets..
TENSION YOUR SOCKS!
Old 10-28-2003, 01:51 PM
