CT944's Avatar
Cool How to remove stock Blaupunkt?
It has the pull out bar, but will not pull out! It is not the radio with 4 holes in the corners.
Also, the radio had "CODE" flashing, how do I find out the Code?
2007 997 TT
1992 500e
Old 10-27-2003, 06:52 PM
lousailor's Avatar
Send a message via AIM to lousailor Send a message via Yahoo to lousailor
You need the radio manual. It should cover removal, and have the code on the cover.
Louie
'85 (Early) 944 - Beater
'87 924S - Crunch/Rebuild
'76 924 - Long Gone
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
Old 10-27-2003, 07:27 PM
Manute's Avatar
I have a blaupunkt now,extraction tool is like a wire tweezer.You have to insert it in the four holes you say,not sure how do you need to move it,but try different positions,it may work.
Donīt know if old blaupunkts are the same,i had a pioneer and it needed a little metal plate to extract it.
Regarding "code"...have you damaged the contacts of the extractable front? If front is damaged,according to an electrician friend of mine,you need to change the radio...
85ī5 951
Old 10-28-2003, 12:01 AM
adrian jaye's Avatar
I had a similar problem with another make.
if it "has" a pull out bar, it MUST just pull out.
if it's not often removed chances are its just very tight, give it a darned old hard tug, OR try short tugs, or try wiglling it from side to side
NO keys are needed with a pullout bar system
CODE, means its been powered down and you need the anti-theft code,
if you dont have this Pawsh dealers can advies, there is a tech bulletin, i dont have access to it, but ask here
The fear of God is the begining of wisdom <><
NotJustPorsche
Subscribe: notjustporsche-subscribe@yahoogroups.com
Old 10-28-2003, 01:51 AM
