Iwhiplashed2's Avatar
Cool early 85 944 from fire to almost fire up
I would first like to say, I've found this site very helpfull as well as entertaining. Any way I bought an early 85 944 about four months ago that was fire damaged (fuel fire engine compartment) then I also bought a parts car that was pretty clean and complete. It had a bent frame rail on the pass. side. Long story short, I've gone about and made one nice car out of the two. Its time to begin testing but I cant get spark. I'm getting the fuel pump to power but not the plugs. I'm just starting to go over the wiring again to make sure I didn't make any mistakes seeing how I had to swap the front, mid, an engine harnesses. Any suggestions would be most helpfull. thanks
early 85 944 n/a red 5spd 67 chevelle ss 396 bb 4spd
Old 10-24-2003, 03:05 AM
SoCal Driver's Avatar
The two sensors on the back of the engine, speed and reference, may be plugged into the others harness. Or the harness wires, specially shielded, may be broken inside. Try swapping them first then checking for spark. Also check that the rear most sensor, speed, is 0.8 mm off of the starter ring teeth. The front sensor, reference, looks at a pin on the flywheel and will just follow the rear sensors adjustment. Also use an ohm meter to check from the center pin to one of the outside pins on the sensors for 0.6k to 2.0k ohms. The other side should be an open circuit as this is the shield.
The other things to look for are voltage to the coil and the injectors with the key on. This should be the same as the battery voltage. Check both sides of the connector to the injectors as the one going to the electronics (DME) will read low. The connection opposite the green wire on the coil should have battery voltage.
If you get battery voltage at the injectors then the first set of contacts in the DME/fuel pump relay are closing. The coil voltage comes directly off of the ignition switch. The voltage going to the injectors is the same circuit that powers the DME.
The fuel pump runs when cranking the car. You should be able to hear it run as the DME trigger circuit times out just after you stop cranking. Open the drivers door and lean over with your head almost under the car. You can bypass the DME/fuel pump relay and run the fuel pump directly by using an alligator tip test lead between aux fuse #3 and #2 (fuel pump fuse).
What year is the donor car?
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-24-2003, 08:38 AM
TCMdocs944's Avatar
Wow, can't beat that answer.
Welcome to the board!
and thanks for bringing one back from the dead.
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 10-24-2003, 09:23 AM
donor car is same vin. # early 85. Thanks, I'm going to check these out now.
Old 10-24-2003, 01:42 PM
Well I got her running, changed fuel relay, ignition switch, two wires under fuse panel, and she came to life.. thanks SoCal Driver for the detailed tips and good luck with the employment status! tt later
Old 10-26-2003, 09:05 AM
Which two wires at the fuse panel? You don't want to have the fuel pump running if the ignition switch is on. This has to be controlled by the DME through the relay.
Old 10-26-2003, 09:39 AM
They were two leads that ran behind the panel (green, black/purple-green, all with speaker termial type plugs, fuel pump is running off dme. Also had to tighten up grounds up above fuse panel, they were loose.
Old 10-26-2003, 03:33 PM
FLA944's Avatar
Send a message via AIM to FLA944 Send a message via Yahoo to FLA944
Congratulations! and welcome to the site.
SoCal is all knowing on the earlies. His wisdom is only outshone by his generosity.
"Ya gotta love the red ones"
Rick
'83 944 "Guards Red"
New Everything (seems like)
16" 968 Wheels
has never left garage (yet)
Old 10-27-2003, 06:37 AM
CT944's Avatar
How difficult was the ignition switch to replace? I am having the "no spark" syndrome, and have just about replaced everything. Will the engine crank over if the ignition switch is bad? Or should I assume that if the engine cranks, the ignition switch is good??
2007 997 TT
1992 500e
Old 10-27-2003, 06:29 PM
Rick
Don't applaud, throw money!
Old 10-27-2003, 11:02 PM
FLA944's Avatar
LOL!
Hugh, how's the smoke over there?
16" 968 Wheels
Old 10-28-2003, 05:36 AM
LOL!
Yesterday was not so bad. Day before was a nuclear winter!
I live about seven to ten miles off of the coast in Orange County California.
Still not as bad a smell as some of the peat bog fires you get down your way.
Old 10-28-2003, 06:39 AM
FLA944's Avatar
yup,
seems like the fires go from one coast to the other.
The rains came back this year so we are OK for now.
You are right about the the smell. The swamp behind me went up and stunk like hell. The critters were running all over the place as there home burned.
I hope you and yours are safe thru this one
Rick
16" 968 Wheels
Old 10-28-2003, 02:07 PM
Thanks everyone for the warm welcome. Actually Its been a little too warm at home, seeing how I've been evacuated from the house. I do, well at least did, so far live in Angelus Oaks off the sr 38. This fire is getting closer all the time. I guess well have to wait and see how this works out. At least I brought my dog to the office that day, just in case.
Old 10-29-2003, 05:20 PM
I've found that my ignition switch would turn the car over but when I releast the key, there was too much play in the switch and would slip by the run position and act as if you turned the car off. Too much play in switch, had to replace.. Was fairly easy, remove plastic cover, steering wheel, plastic sleeve on steering shaft, turn signal assembley, then you can remove switch after removing the allen bolt from lower left side.
Old 10-29-2003, 05:37 PM
