Stupid Timing belt
Im tired of worring about the timing belt. I check the belt and its fine and it feels tensioned and stuff, but im not completly sure. I dont have the special 5000 dollars tool to do it myself, and i dont know anybody around here that can replace porsche timing belts. The only guy who works on porsche's, i think is crappy and will do it wrong. Should i go to the Porsche dealer? If not, is this something a kid can do?
And how come that stupid 20 dollar piece of rubber can do 1500 dollars worth of damage to our engines? whats up with that
86' Porsche 944 N/a |
I'm off the hook.....
Where are you? Nothing in your ID or signature says anything about that.
No, I don't sing. Based there for too long. |
vott does ziss do?
if you don't have any experience doing the belt yourself, it is better left to a professional mechanic. and since you don't trust the local guy it would be better to take it to the dealer. the few hundred dollars you spend will be well worth it in the long-run
Yes, go to a dealer, esp. if you don't want your location revealed to let peeps tell you of a reputable shop. or check with your local PCA, they will let you know the best shops in your area to work on your car.
*Disclaimer: The person above is actually dumber than he appears. my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements '84 944 auto/ps/ac/cc '86 951 Providing ignorance one post at a time. |
Writer/Teacher
well we just had a timing belt replacement party in CT, and there was one two weeks earlier in CA. Maybe you could organize one in your region?
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944. |
You have a couple of choices. One is to update your engine to use the spring loaded belt tensioner. The other is to rent the tension measuring tool (usually about $75.00). Either way, you will know that you won't have a problem with the timing belt.
Good Luck! Fred Cook '88 924S (Before) '80 911SC coupe (Now)
Autobahn Garage
Hey Rock I live in N/W Ohio if you can get it to me I will do it for you, Where do you live??
T Tanner 76, 911s w/ Webers 76, 914/4 57, Speedster |
special tool - where to rent?
Hi,
I am gearing up to do my first timing belt remove/replace and the last bit I need to arrange for is the tool ... Is there a place (other than the other board) where I can rent one of the special critters? I've been on the other list (I'm a member there) and the guy that handles the tool loan thing hasn't emailed me back. Kind Regards, DL
84 944 5spd Maint. & Fixes made thanks to the help received on this board: Rear Hatch Pins, Oil Change, Dash Cover Installation, New Rear Seat, New O2 Sensor, New Ignition Switch, New Fuel Pump Relay, Rear Light Assembly Reseal, Instrument Panel Short Circuit, New Speedo Cable, New Timing belts and Starter. |
Re: Stupid Timing belt
1988 951 Alpine White / Burgandy Profec B spec II EBC,HomeBrew Chips, WideFire HG, Tial 38mm, Magnecor Wires, Koni Rears, Adj Rear Droplinks, Zeitronix WideBand. |
tanner! i live in cincinnati ohio, its like south west
vott does ziss do?
