Brian J's Avatar
Send a message via Yahoo to Brian J
Porsche Crest water wetter
Has anyone used this stuff?
WaterWetter with Rust & Corrosion Inhibitor is a unique wetting agent for cooling systems which reduces coolant temperatures by as much as 30F. This liquid product can be used to provide rust and corrosion protection in plain water for racing engines, which provides much better heat transfer properties than glycol-based antifreeze. Or it can be added to new or used antifreeze to improve the heat transfer of ethylene and propylene glycol systems. Designed for modern aluminum, cast iron, copper, brass, and bronze systems.
Drive it the way it was built to be driven!
http://www.pelicanparts.com/gallery/Brian_J
Old 10-30-2003, 06:59 AM
ds475's Avatar
Send a message via AIM to ds475
i've seen/heard about it, i'm gonna get some when i do my coolant flush
'82 928S
'85.0 944 Not Awesome - Being Parted Out
Old 10-30-2003, 09:00 AM
It works as advertised. Good product.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 10-30-2003, 09:14 AM
ds475's Avatar
how much is that stuff? (from pelican?)
'82 928S
Old 10-30-2003, 02:52 PM
Kirby2's Avatar
I always use when it when I flush and refill the cooling system as sort of an insurance policy. It is pretty tried and true technology. It alters surface tension, so you get better contact with the coolant; this way it makes the cooling fluid more efficient in transferring heat.
03 Silver PT Turbo - Ours
86 White 951 - His
86 White 944 Manual - Hers
98 C-4 Sons
86 Gold 944 Auto - Sons
84 Maroon 944 Auto - salvaged
78 Yellow 924 - found a new home
Old 10-30-2003, 03:14 PM
Kirby2's Avatar
Water Wetter is nothing like antifreeze, it has NO lubricating qualities, and it does not have stop leak properties, have anticorrosive properties, or prevent freezing. One colored water is not the same as another.
Run your engine without water pump lubricant and find out the hard way how dificult a water pump replacement really is!
86 White 951 - His
98 C-4 Sons
Old 10-30-2003, 05:23 PM
fty fty is offline
fty's Avatar
Send a message via AIM to fty
Used it a few years back when my car was over heating due to a loose timing belt on the water pump roller...worked great and got me home in one piece..lowered temp by atleast 15 degrees-chris
82' 911 SC"Go Go Green" 87'3.2L,Turbo Brakes,Brake Bias Valve,Fiberglass Front Clip, 16" BBS, Multiple Strut Braces, Re-valved Bilstiens and a few more "Stock" additions. SOLD
04' Audi A4 Avant Quattro S-line- RS6 look alike with half the HP
http://www.eurocompulsion.net
Old 10-30-2003, 07:05 PM
Kirby2's Avatar
Please don't get defensive, there is a difference in the setup you use for racing, where absolute performance matters. Antifreeze is not as good a heat transfer agent as water, no question. Water and Water Wetter is an even better heat transfer agent. In a race where heat is the enemy..it is the right thing to do.
If you care for your car as most of us do, the stock cooling system with a little kick from adding Water Wetter to our Required mixture of 50% antifreeze and water works just fine. I would recommend draining your fluid and going with the water and surfactant for weekend racing, but for weekenders, or daily drivers, there is a reason that Porsche demanded 50% antifreeze for warranty.
86 White 951 - His
98 C-4 Sons
Old 10-30-2003, 09:03 PM
Brian J's Avatar
$7.95 per bottle
Old 10-31-2003, 05:32 AM
Brian J's Avatar
Kirby2
I plan on running my daily driver on a 50/50 solution of water and anti-freeze. What I was looking for was an additive to help the cooling system be more efficient. But before adding "miracle" products I just need to know if it;
1. works
2. does any damage
3. worth my $$
Old 10-31-2003, 05:36 AM
Kirby2's Avatar
1. Yes
2. NO
3. Depends on how hot your ride runs when you compete.
4. This product has been available for years and as our friend that erased his posts mentioned , it has been a staple for racers that push the limits of their cooling systems.
I just wanted to try to steer the uninformed away from thinking it was a high tech replacement for antifreeze.
86 White 951 - His
98 C-4 Sons
Old 10-31-2003, 08:10 AM
Works great.
Lowered my temps at least 3/4 of a tick mark on the temp gage. Just enough to go from kind-of nervous, to perfectly fine.
I use a 50/50 mix of antifreeze, and water, and throw in a bottle of water wetter. (I guess that works out to something like 47%, 47%, 6%, but what's a few % between friends?)
Mike
Old 10-31-2003, 09:28 AM
Brian J's Avatar
Originally posted by mike944
Works great.
Mike
Do you run your car every day?
Old 10-31-2003, 09:47 AM
No, I usually do not drive my car every day, although i have been putting quite a few miles on this week, since my primairy car died. I usually drive it on nice days, no rain, not too cold, not too hot out, because it used to run a little hot (almost 3/4 on the gauge) i was nervous about driving it when it was hot out. Now....after the water wetter, no problem regardless of temperature.
Mike
Old 10-31-2003, 11:47 AM
ae1969's Avatar
Send a message via ICQ to ae1969
I can't see any reason you would use it unless you are experiencing over heating issues. I wouldn't want to mask problems that may be present in the cooling system.
If your car is running too hot you have to find out why.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 10-31-2003, 11:56 AM
..P ..P is offline
I've used it and I think it works.
P
1983 928S 5-speed, 1984 944, 1990 944S2 Cabriolet
My other car is a Chris Craft Commander
http://www.chriscraftcommander.com
Old 10-31-2003, 12:25 PM
Brian J's Avatar
Mike
I'm like Jimmy Buffet..
Tuesday,
Thursday,
Saturday.
The rest of the time my trusty GMC truck.
Old 10-31-2003, 12:57 PM
Brian J's Avatar
The car was running near the danger zone when less than 50mph. Had my mechanic check it out and he found someone installed the incorrect thermostat. Now at low speed the temp gauge is straight up 12 o'clock. At 50+ it will creep to the next mark but never go above that mark. Before, it would just keep on going to near the DANGER zone.
I was looking at some product to lower or stabilze the temps.
Old 10-31-2003, 01:00 PM
Kirby2's Avatar
Think seriously about installing a new radiator soon (only about $200). Small passages crud up with time, nothing you can do about it. A new radiator will keep the peg near the first notch, and you will sleep better at night.
86 White 951 - His
98 C-4 Sons
Old 10-31-2003, 02:29 PM
I agree 100% but if the system is working properly, a little insurance is welcomed. It is tried and trued and helps to lube the water pump and in my book any thing that will help the water pump stay reliable between timing maintence intervals (belts, water pump, rollers) is going in my car.
BTW for the guys in Canada, Redline Water Wetter is available through Canadian Tire stores. At this time the only CT store that I know of that has it on the shelf is the new CT store in Markham (Markham/14th Ave). You can order any of the Redline products that can be used in the 944 throught a special Parts and Accesssories catalog.
Mark
'86 944NA
Old 11-01-2003, 07:55 PM
