entertaining the idea
What is this?
What is this?
My mechanic found it today, it is between the 2 and 3 cylinder on the intake manifold. It appears to be a sensor, but it isn't connected.
There are some who call me... 'Tim'. a well set-up 1983 Guards Red 944 |
Looks like a temp sensor to me. How is it mounted?
Was there an after market temp gauge in the cab somewhere?
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
It is mounted with one of the bolts that holds on the manifold.
There is no after market temp guage in the cab, but there were new guages for the oil pressure and clock that the dealer installed. (which I have since replaced to the stock yellow ones). We also found what looks like an after market cruise control system that was disconnected.
Bet the new gauges replaced the after market temp gauge.
How do you know it's a limited slip diff?
Thanks for the help! I was hoping it was an after market temp sensor.
On the option codes in the car, I have 220 for LSD.
Don't know of many 83's that came with LSD's.
Me either, I read here that LSD came with 16" wheels and sway bars...
I would be curious to know how many where made with LSD.
My 83 has LSD.
The '84 I just sold has an LSD tranny.
Cliff Hipsher '87 944 India Red '86 951 Kalahari Metallic |
