ds475's Avatar
Send a message via AIM to ds475
Latch to pop hood - BROKE
ok, the latch inside the car that you pull, to pop the hood, broke. i can no longer pop my hood to plug in my radiator fans... this isn't good. not to mention, under the hood is a relatively important place to be able to access... i'd rather just rig up the wire so i can pop the hood, because the old assembly seemed cheap (since it broke) but i can't believe how much strength is required to hold the wire sleeve in order to be able to pull the wire to pop the hood. i attempted to hold the sleeve and pull the wire, and it didn't move a millimeter. any ideas? anyone got one of the levers from a parted out car?
'82 928S
'85.0 944 Not Awesome - Being Parted Out
Old 11-02-2003, 02:14 PM
Verruckt's Avatar
You can buy the handle and the frame that it goes in here at Pelican Parts. This was the first fix on my 924S.
The crashes people remember, but drivers remember the near misses. Mario Andretti
1991 944S2 Rally #951 Rally-America.com
Old 11-02-2003, 03:28 PM
stray15's Avatar
Send a message via AIM to stray15
crow bar
Old 11-02-2003, 06:38 PM
use some scissors to hold back the sheeth and use some pliers to pull on the lenght of wire still there. It'll take some muscle, but you can do it. I did that for about a month before I realized that little plastic lever and housing assembly is like $20, less if you just need the lever or housing.
Old 11-02-2003, 07:38 PM
This just happened to me. You need 2 people. Get under the front of the car on your back, and look up behind the radiator, you will see the latch assembly. Look for the thing that the cable attatches to. Now, have your partner push down on the hood in the middle where the latch would be to release pressure on the assembly. While they are pushing down reach up with either your hand or a screwdriver and push the thing that the cable attatches to to the LEFT(drivers side from your position). It should unlatch. This will at least get your hood open. Hopefully you can follow what I said.
Mike
Old 11-03-2003, 05:30 PM
ds475's Avatar
well, currently, i have to pop my hood, and plug my radiator fans in... apparently, i put years of use into that pos holder... i just keep it under 3k RPM's... until i get my new thermo-switch and hood popper assembly...
'82 928S
Old 11-03-2003, 06:11 PM
