ds475's Avatar
Send a message via AIM to ds475
Thermo-switch or Thermostat?
the thermo-switch, is the thing that turns on the radiator fans, correct? i'm going to borrow a multi-meter from work tomorrow to test my thermoswitch, although there is no doubt in my mind, that it is bad... since my radiator fans would occasionally/never come on automatically...
'82 928S
'85.0 944 Not Awesome - Being Parted Out
Old 11-03-2003, 12:01 AM
bearone2's Avatar
haynes manual has a pretty simple test.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 11-03-2003, 08:13 AM
Nabeel's Avatar
Send a message via AIM to Nabeel
Most likely the thermoswitch gone bad. If not, check the fan relay, although it is most likely the thermoswitch in this case.
'85.5 944
Kalahari Beige/Brown
5-speed
76K miles
color-matched fuchs
SOLD
Old 11-03-2003, 08:15 AM
Send a message via AIM to TheCooler
A quick fix is to buy a 2 way toggle switch from autozone or radio shack and hook up some wire to the swich then to the fan switch plugs and u can switch the fans on of off when u want to from inside the car. its a cheap fix for the moment until you get the new thermoswitch.
-2002.5 GTI VR6 24V 6SPD
-Kalahari Beige 89 Porsche 944S2
-87 VW GTI 1.8 16v
-2007 Ford PIMP(free)star ...company car....
-1999.5 Jetta VR6
Old 11-03-2003, 08:41 AM
SoCal Driver's Avatar
Borrow a multi meter? Why don't you buy one? That and a 12 VDC test light.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 11-03-2003, 12:04 PM
bearone2's Avatar
thermo switch is the same part# for an '84 rabbit.
Old 11-03-2003, 02:52 PM
ds475's Avatar
dammit, i wonder if it is cheaper for the rabbit? i had already ordered the thermo-switch anyway last night from pelican, i was just making sure i did the right thing...
'82 928S
Old 11-03-2003, 03:42 PM
ds475's Avatar
eh, $9 for the "porsche" thermo-switch, $8.52 for the "VW" thermo-switch...
'82 928S
Old 11-03-2003, 03:45 PM
Just thinking out loud
mattdavis11's Avatar
ds475, I have a multimeter and a test light, along with a new thermo switch I need to put in my 83. Is your's early or late 85? I procrastinate, but my fans work, at a later temp than b4, though.
91 FJ80
84 Ram Charger (now gone)
Old 11-04-2003, 10:09 AM
ds475's Avatar
early 85. i was also wondering, is coolant going to drain out when i take the old thermoswitch out, to put in the new one?
what do you need the multimeter/test ligtht for if you already have the new thermo-switch? if i were you, i wouldn't even screw with testing the old one... just slap the new one in.
'82 928S
Old 11-04-2003, 03:31 PM
You will lose coolant. How much depends on how fast your are.
Bob S. former owner of a 1984 silver 944
Old 11-04-2003, 06:49 PM
ds475, I'm just going to change it out. The reference I made about the multimeter and test light was an offer (which I didn't clearly state, my bad) to the fact that you are welcome to use mine if you ever wanted or need one. There are few here that live in Austin, I'm always willing to help out a fellow pelicanhead. Now about those , go to autozone and by the Bosch arms and blades, they are only about $9, and work well.
Old 11-05-2003, 08:38 AM
ds475's Avatar
Matt, i didn't realize you were in Austin! that's cool, i've met a guy off here from Austin (Keith Lawlor) i don't remember his Pelican user name though... I'm David btw... i'll PM you sometime... i appreciate the offer!!! thanks!
'82 928S
Old 11-06-2003, 09:15 AM
bearone2's Avatar
what does "btw" mean
it's easy enuff to drain/add coolant.
i think i paid about $17 for a porsche sending unit/+shipping and would have been able to get the cheaper one locally and not had to pay shipping but didn't know about it at the time.
ain't hindsite always 20/20.
Old 11-06-2003, 09:36 AM
ds475's Avatar
BTW = By The Way
'82 928S
Old 11-06-2003, 09:45 AM
bearone2's Avatar
ds475, thank you.
Old 11-06-2003, 04:47 PM
ds475's Avatar
what if i tilt my car forward by jacking up the ass? that way the coolant will go to the front, rather than the back.
'82 928S
Old 11-06-2003, 06:48 PM
bearone2's Avatar
you're going to lose some fluid no matter how you do it.
you also have a drain on the bottom of the radiator on the left side
Old 11-06-2003, 06:53 PM
ds475's Avatar
well, would i lose so much that i would have to add some, or is it going to flow out fast? dammit... maybe i should just empty it, and put some fresh stuff in...
'82 928S
Old 11-06-2003, 07:00 PM
bearone2's Avatar
if it's been over two years, a good idea.
Old 11-06-2003, 07:04 PM
