-   -   New or Rebuilt Injectors (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/134298-new-rebuilt-injectors.html)
Verruckt 11-03-2003 11:10 PM
Half of my injectors are suspect. I know that there are several companies that rebuild them, but are they able to bring them back after they have 148,000 miles on them? Is it better to just buy NOS bosch injectors?
highboost951 11-03-2003 11:22 PM
have them rebuilt, if they're not rebuildable I'm sure they'll let you know. It obviously costs a whole lot less and you will even get a set of flow matched injectors, good luck buying some new ones and getting the same result. If you're worried about down time, buy a cheap used set and have them sent directly to a rebuilder, then direct to you.
Manute 11-04-2003 01:23 AM
I would buy them new....they cost about $80 each and you are sure to have no leaks in lots of time.
SoCal Driver 11-04-2003 08:27 AM
I've always wondered how you rebuild an injector that has one moving part and is swedged together.
Verruckt 11-04-2003 09:06 AM
Exactly SoCal! What do they do to make it stop having post nasal drip, and then balance them? Do they have to glue them back together when they are done playing with the injectors guts? Inquiring minds want to know.
ae1969 11-04-2003 09:09 AM
I have a set of NA injectors from my 86' that were cleaned/flow matched by rcengineering (comes with printout) all of them to spec. Make me an offer an they are yours. :)
SoCal Driver 11-04-2003 10:00 AM
How did they do it if they can't take them part?
mattdavis11 11-04-2003 10:29 AM
SoCal, you, of all people should know that a carpenter's knife, super glue, and duct tape can fix an injector.;) Just kidding. No need for fires, fix it right. SmileWavy
highboost951 11-04-2003 02:49 PM
The process is simple and straight forward. There are reputable shops and "home town hole-in-the walls" which can rebuild, flow test and match the injectors with good results. As with anything, do a little research and pick a good company. The company that did '69s injectors are a very well known outfit. I'm not aware of a need to
2 split the halves, but I have seen a stock bosch 951 injector that "appeared" to have been rebuilt which was leaking at the seam of the metal bod. The injectors are ultrasonically cleaned and the o-rings, caps, and filter is replaced. They work the crap out of the injectors on special equipment to clean them. Typically injectors just need to be cleaned, it's not usual for them to fail mechanically. They flow them before and after, and will repeat the process to achieve the desirable #'s and try to get them very close to each other. I remember Tony G getting some 951 35# injectors rebuilt and they got them flowing upwards to 43-45#'s! I don't know why having them rebuilt wouldn't classify as "fixing it right", but if you're worried about fuel rail fires, protecting or making full use of your new injectors, I'd highly recommend that you also add some things to your shopping list: If they haven't been recently replaced, you may look into a new fuel rail, dampner, regulator, fuel filter, in-tank screen filter and of course the fuel lines(when were they replaced)? you can spend $100-$125 getting all 4 refurbed or drop $80 on each one.
highboost951 11-04-2003 02:57 PM
or for $50 plus shipping for the same thing as RC(in the High perf. injector market for 30years):
http://www.affordable-fuel-injection.com/fuel-injector-cleaning.htm
don't you think there would be some liability issues that they'd be worried about if rebuilding injectors wasn't successful and led to external leaks causing fires? I haven't heard any bad reviews about any rebuilder other than someone finding another source that would do it for less. I think I'd go with experience over price, but 1/2 price is pretty tempting, do some research on some others.
SoCal Driver 11-04-2003 03:11 PM
With out taking the injectors apart calling them "rebuilt" is erroneous.
Cleaning injectors is easy for any one with a piece of tubing, solvent and shop air. Would do it all the time at VW dealers.
Now how would you change the flow if you can't take it apart? Is there a set screw hidden somewhere that controls the flow of fuel?
Changing the plastic "hat" and o-rings is like resealing the front of the engine. I wouldn't call the engine rebuilt.
Now I've seen a bunch of injectors cleaned and matched for flow and spray pattern.
ae1969 11-04-2003 03:20 PM
...well highboost explained how they clean them so I will leave it at that....
The printout that RCengineering sends out shows the flow characteristics of the injectors before and after.
on a side note: Its an interesting point highboost brings up in regards to Tonys injectors. I had a friend who saw the same thing from so called 55lb injectors. After having them put through one of these procedures he was able to increase the flow to ~72. I am not sure how some of these injectors are calibrated but it seems that you can definitely alter their flow characteristics........ Even accross different manufacturers you can get some interesting results.
SoCal Driver 11-04-2003 04:11 PM
Cleaned them. Not rebuilt as is claimed.
ae1969 11-04-2003 08:46 PM
Yup thats right they clean them but they also test to make sure the injector is working as it was intended (the mechanicals, resistance in the coil, spray patterns). There may be rebuildable injectors? Not sure of that actually?
They explain part of the testing/cleaning procedures on their website.... www.rceng.com
highboost951 11-04-2003 10:38 PM
I don't see your problem socal, if you're unhappy with the terms, talk to the companies that do the service. As the saying goes, if it ain't broke, don't fix it. If cleaning is all that's needed for them to be in "like new" or a "rebuilt" condition, then so be it. They have replaced the necessary worn parts to make it operate as or better than new. who cares what they call it, it's a good inexpensive service when compared to the cost of new ones and the results speak for themselves. It's basically an industry standard, remanufactured or rebuilt parts are sold all the time with only the necessary items replaced.
SoCal Driver 11-04-2003 10:53 PM
I checked several companies that do this and none of them call their service rebuilding.
The worn parts they replace are the same parts you can buy at Pep Boys for $3 per injector -- two o-rings and a plastic "hat".
They do use a high power ultrasonic cleaning bath while they are back flushed. Possibly a bit better than just back flushing them with solvent and shop air but still the same operation.
The injector can not be taken apart so any insinuation that these are "rebuilt" is totally bogus.
I've been cleaning injectors since 1970. How long have you been cleaning them?
highboost951 11-05-2003 02:00 AM
...that were cleaned/flow matched by rcengineering (comes with printout) all of them to spec. ....
You wrote: How did they do it if they can't take them part?
"I've been cleaning injectors since 1970. How long have you been cleaning them?"
Wow, very impressive; So you've been doing this approach since 1970 eh? I'm sure it would work fine for mfi or cis injectors but are you saying you'd use this approach on a motronic car? the injectors need to be juiced to let fuel through, I'd love to see you go to town on them with an air compressor. Sorry but I prefer to see real #'s vs. a "ooh I think I cleaned it pretty well". I've got too much invested to use your approach, I'd rather spend the extra money and rest assured; especially with the euro spec 2.2S race motor or with the 95# injectors on my 951 when running 25+ #'s of boost. who gives a crap about the definition of them being rebuilt, for simplistics I was giving a recommendation about "rebuilt" injectors as asked in the post. As I said before, they typically don't fail mechanically, they just get dirty and need a good cleaning. Obviously you seem to be inclined to cleaning them too as this is what you've been doing for the last 30 years. I was recommending to have them done vs. spending the money for new ones. It's pretty lame to have such a strong opinion about the fact that they aren't "rebuilt". The term was just loosely used in the question and it was repeated. I really don't know what your trying to achieve other than foolishness; they take injectors which people think are ready for the trash and bring them back to better than new spec for less than a 1/4 of the cost of new ones but you can't generally call them "rebuilt" on the general principle that they didn't cut them open. They don't open them because they're capable of cleaning them w/o having to do that and the #'s prove it. I'd love to see what kind of improvements they could make on one of your "cleaned" injectors. Maybe I can talk a builder into cutting them in 1/2 and welding them back together, then it would be "rebuilt"...right?
Dark Skies 11-05-2003 04:37 AM
My tuppence ha'penny.
If half my injectors were suspect I'd have a go at cleaning them all using the 'rocking' method and some injector cleaner as I've described elsewhere.
If that didn't work then (depending on the plumpness of my wallet at the time) I'd either buy two second hand injectors (figuring they'd be roughly the same mileage as the two survivors) or a full set of nice new units.
I wouldn't pay half-price to have them cleaned because they'd just be the same tired old items (but cleaner) at the end of the day. I would pay to have them serviced if they are of the rebuildable type because then they'be be essentially reconditioned to as new for half the price.
I noticed the debate getting a little heated on the subject or rebuilding. Depending on the external body design you can rebuild injectors relatively simply. I've done it a fair few times on my Z1000-H which has Bosche K-tronic injection. If you look at the pic of one mine you can see a little retaining screw just under the electrical connection. Unscrewing this allows you to unscrew the main injector body casing and access the internal mechanism.
A lot of bollocks is spoken about fuel injectors - like they're some kind of guru-mech subject. Essentially all an injector is is an electrical gate. It has a spring-loaded precision metering needle that lifts of it's seat when the electrical actuator comes into play. The fuel, already under pressure, rushes through until the actuator closes it. And that's all it does. Eventually the needle and the precision bore through which it slides will become worn with age allowing it to leak and throwing out the precision metering slightly.
I've attached a cutaway pic gleaned from a Kawasaki bike mech training course I did years back so you can see how little there is to it. It was supplied by Bosche (it looks like a diesel injector to me)
Sometimes you can access the components and replace parts (if you're in the know as to where to obtain them). Sometimes access is denied due to the casing design. I haven't looked at my Porsche injectors for a while but i believe they're the sealed unit type.
Either way they're nothing to get your knickers in a twist over.
http://forums.pelicanparts.com/uploa...1068035826.gif http://forums.pelicanparts.com/uploa...1068035851.jpg
SoCal Driver 11-05-2003 08:40 AM
Yes on motronic cars. This is a shop procedure recommended by Bosch and was taught at the Culver City VW-Porsche instruction center. Either the injectors worked or didn't. Back flushing "corrected" about 90% of the problems.
DK, that is not a screw. That is an opening in the plastic where you can see the metal of the injector housing. Here look at this cross section:
http://frwilk.com/944dme/injector.htm
The plastic is moulded around the metal of the injector.
I too would like to know how these can be "flow corrected" if you can't open them up. If you can open them then I would like to know how.
I'm sticking to my argument that rebuilt means the item is taken apart and mechanically wearing components are replaced or brought back to OEM spec. Changing the flow also means you have taken them appart and modifed the internal structure.
Cleaning means back flushing and possibly ultrasonic immersion to assist in cleaning.
ae1969 11-05-2003 09:57 AM
I would imagine if you cleaned them that the flow would improve if the filter(mesh) inside was dirty and it was back flushed?
I would assume if after said cleaning/testing (or whatever we are calling it) and that the flow improved back to the injectors specs? Can't you assume that it is working fine? and thus we corrected the flow?
Good question on changing the flow of an imjector above the stated specs. The problem is that flow of an injector can be different. That difference is usually related to fuel rail pressure....... ex. 55lbs at 3 bar...... but that injector could flow much differently at 2.5 bar or maybe lock up at 4 bar.
Dark Skies 11-05-2003 11:22 AM
I think we're talking at cross puppies. :) The injectors on my Kwacker are totally strippable. You can disassemble everything bar the electrical switching jobbie. I've looked at the cross-section and it is radically different to the ones on my bike. On my injectors there's a grub screw that turns about three turns out - this allows the body to unscrew and pull away so as to allow access to the internals which can then be removed. You can (or you used to be able to anyways) get a little rebuild kit with o rings and replaceable components to service it with. The grubscrew locates into the top of the threaded body which has a slight dimple in it. This is so that you know the o ring is sufficiently compressed to seal the unit properly.
Externally the unit looks like any other Bosche affair. The onboard computer and airmeter are Bosche - I'm assuming the injectors are too but I could be wrong - it may be a Kawasaki made unit.
Admitedly the bike injectors are the only ones I've actually had experience of pulling apart - like I said I believe the Porsche units are all sealed. When I last had cause to 'rock' them (is that the same as backflushing?) I don't recall seeing any way to pull them apart - although they looked very similar to the Kwacker units.
There could be a good reason why Kawasaki fitted serviceable injectors. In 1980 Kawasaki brought out the very first commercially manufactured fuel injected motorcyle - the KZ 1000 - H. Shortly after that they also brought out the GPZ 1100i and the KZ 1300 D Kawasaki have always been refreshingly good about using as many common components as they could throughout their range - making life much more simple for those who spanner on their bikes. It's possible they made the injectors strippable in order to interchange them with the afore mentioned bikes with only a few slight changes in the nozzle internals.
SoCal Driver 11-05-2003 01:59 PM
Well I just talked with the RCEngineering tech (possibly owner) and he says they "balance" the injectors. When I pressed him on this balance thing he admitted that they do not take the injectors apart they just clean the heck out of them. This brings the injectors back to within 2% of each other and thus they are "balanced".
Pure BS! You might as well have some one just clean a set at $50 than spend $28 each for the same service.
However he also admitted that they can take one of the Bosch injectors apart once and change the insides for custom applications (read Big Buck$ here). He was adamant that this is NOT the $28 service.
If an injector is found to be uncleanable, such as a leak at a seam, it is returned to the customer with a note.
Thus they do not rebuild injectors. They clean and flow test providing a graph of their findings.
ae1969 11-05-2003 02:41 PM
...uhmmm I'll have to disagree with you Socal.
Injector cleaning is not as simple as using some carb cleaner and blowing air through them. Injectors generally do not fail mechanically but rather microscopic debris/ additives in gas etc accumulate and affect the flow patterns of injectors....
The choice of solvents and frequency of ultrasound to use is not what I would consider a back yard mechanic to have access to. So injectors that are cleaned (rebuilt I guess you could call it that) are adequate especially when you are looking at $80/injector and higher in other cars (150 in my friends landrover). So for a ~30-50 bucks to be cleaned right and having a set that is documented to flow at a certain spec I would think would be more than adequate.
.... on side note: most of the industry uses the term rebuilt when it comes to cleaning injectors not just highboost951.....heheheh... The definition seems to be implied as long as the part is returned to OEM spec regardless if you can slice it open and see the parts for yourself...
SoCal Driver 11-05-2003 04:37 PM
You will not find the word "rebuilt" on either of the listed web sites in regards to the Bosch 944 type injector.
ae1969 11-05-2003 05:04 PM
These guys up here managed to send out a bosch injector to be rebuilt? But what do they know?
Check step number 19....
http://www.pcaucr.org/pcaucr/site.nsf/Public/321d3231a7906d568525694000007ffa
SoCal Driver 11-05-2003 05:12 PM
Ignorance is bliss. Most call it a motor. A few others it's correct term; engine.
Then a crap pile of money makes everything ducky.
highboost951 11-05-2003 06:40 PM
Okay, I should bite my tongue but....I can't, I'm young and weak...okay, I'm going to say it...Socal, I don't think anyone really gives a **** other than you. You must have a lot of spare time on your hands to be worried about the "rebuilt" fuel injector conspiracy, especially after hearing that you took the time to give RC' the shakedown and waste theirs.
highboost951 11-05-2003 06:43 PM
damn censorship
SoCal Driver 11-05-2003 08:15 PM
So you don't think that the 944 consumer should know what they are really getting for their money?
Cleaning the injectors is something most can do at home as long as they have a two or three foot piece of tubing, some solvents and a compressor.
This saves at the minimun $50 if not $120 minus the $12 for the four o-ring kits. May not be 99.9% but I'll bet that no one here can tell the difference between the two methodes.
highboost951 11-06-2003 12:08 PM
first off thanks for not killing me after that post!!! it was a mix of humor, stress relieve, and a bit of stab. I think we're justing kinda pissing in the wind here but oh well.
Regarding my stance on informing the 944 consumers...I think you know the answer to that; I recall saying that buying new ones would be a waste of cash since having them "rebuilt" would give the same results at a fraction of the cost. The majority of my posts are answering questions, not asking them.
I'm still puzzled at what your trying to accomplish. When you were cleaning the injectors back in the '70's, those were manual CIS and MFI injectors. You're forgetting the need to electrically open the 944 injector. I'd be careful what you're suggesting others to do, let's look at your recipe for disaster, compressed air(lots of oxygen), combustable liquids/gases, and electricity/possible sparks.
You make a very good point about how no one would be able to tell the difference, even yourself. This is funny because that's exactly the problem, do you think the typical 951 owner who blew his headgasket from running lean "knew" that one of his injectors wasn't quite up to par but continued to flog it anyway?
A ping is pretty easy to hear and correct on a n/a motor; a simple band-aid is higher octane. The turbo is different story, hearing ping on a turbo when you're already using high octace fuel is a little more scary, burnt valves and blown headgaskets come to mind.
Ultrasonic cleaning, according to the Society of Automotive Engineers, is the most effective and safe cleaning method. You couldn't even compare spending your method at $12.50 to the value of spending $55 total to achieve factory spec and within 2% of one another.
When trying to tune a motor using a/f ratios and running increased fuel pressures and bigger injectors, it's a necessity to have matched injectors, otherwise as I said earlier, you're pissing in the wind. typically readings are combined from all cylinders, or an average, in turn with w/o matched injectors the same thing happens on tuning, if one is not up to par, it pulls down the overall A/F ratio, then the others are ran even richer to cover the bad one. see this being a problem? It's not just turbos that I'm talking about either.
If the whole world was just driving '83 944's w/o mods or seeing track use then....it's not a perfect world either.
SoCal Driver 11-06-2003 04:38 PM
Back pressure will open the Bosch electro magnetic injectors.
Yes our Bosch injector is basically mechanically the same injectors as are used in the 1970's VW's. They are not the CIS or MFI.
1970 VW-Bosch injector
You can tell how rich or lean a cylinder is running from the spark plug.
If it suits someone's need then have the injectors professionally cleaned then do so. I'm pointing out that this is NOT rebuilding as the injectors are never disassembled. I would not call replacing the strainer screen rebuilding.
The "balancing" is erroneous too. When you send your injectors to be cleaned the service will test the flow rates after the cleaning and give you a sheet showing how each injector performed. It's up to you to match up a set of injectors.
The turbo has a knock detector and will retard the timing.
kuffs565 11-12-2003 08:12 PM
SO Cal Driver, Im getting ready to pull my injectors out and clean them on my own. Can you tell me how YOU do it. I have all the tools you speak of and would like to try it myself first. The car sat for 3 years without being started now after flushing the fuel system it running crappy. Think the injector Cleaning would help alot. Have replaced the fuel pump.
