what is wrong
I have an 83 844
it sometimes has trouble starting feels like it is not getting gas. If I let it sit for 5 or 10 min it will start fine. This has been happening more frequently lately. could it be a fule pump if so what is nessessary to replace it? |
When was the last time you replaced your fuel filter?
Could also be the reference and speed sensors. Been a rash of these lately breaking their wires inside the connectors or the plastic heads. Please put your car and year in your signiture line. |
DME relay... stops flow of fuel when it dies... intermittently
so perhaps a dme relay or fuel filter. Are either of these things something that i could fix myself I have no mechinacal experience beyond changing my oil and fooling around with two cycles
All you need is a jack, jack stand, and wrenches (17mm and 19mm?) to change your fuel filter. All you need to change your dme relay is nimble fingers and your owners manual.
how much would they cost which should i do first?
Do the DME relay first..... check the date stamped on it. If its older than 5 years more than likely you will need to replace.
The fuel filter can be a PITA to replace unless you enjoy getting covered in gas. Now you mention 5-10 minutes you wait and then it starts............is this on cold starts or hot starts??? |
cold starts
but on warm days i have not driven the car since summer but I am trying to get this thing fixed during the winter so I can enjoy her during the summer
so you guys are pretty sure that it is not the actual fule pump itself
that is good news |
Did you? |
| All times are GMT -8. The time now is 01:35 AM. |
