Removing Front Fender - Help.
Hey guys, after replacing my brake pads the other day, I forgot to pump the pedal before moving the car, and so I ended up denting the front tip of my driver's side fender.
Should I remove the whole panel to try to hammer it out, or is it too hard? Otherwise I will have to pull the dent out. Thanks. E 1984 944 |
If the paints not cracked or broken, try taking your car to one of the new "Paintless" dent removal services. These guys, if you have them in your area, work wonders. I saw them pull three good door dings from a early z-car with no paintwork needed. The key to success for them is that the paint film must be intack.
I think that the paint is scratched a bit, I can see the primer under.
The other thing is that I just found out I have to cut my nose panel loose, since mine is NOT removable, so I have to take it out too to fix a dent, paint, then install a new head crest. E |
| All times are GMT -8. The time now is 01:17 PM. |
