ds475's Avatar
Send a message via AIM to ds475
Strange hummin' from my rear
Lately I've noticed a strange humming coming from behind me in my car. i don't have the seats or any sound deadening in, so i hear everything. It isn't consistent, or repetitive, but kind of off and on and different volumes, kind of like two people conversing... different frequencies, volumes, rhythms.
Whether it is in gear or not, or the clutch is pushed or not, it still makes the sound, the sound doesn't change with a change in engine speed. Could it be CV related since the sound doesn't change with a change in the engine/transmission "tests"?
also, i've never noticed this till today, and since a cool front came in, i haven't THOUGHT i had to pop my hood and put my radiator fans on, because it was cool enough to cool my engine, while moving. i never got but just barely over 1/2 way, even after running it vigorously and for a while. might i add, it was running great :-)
but, today i got stuck in stop and go traffic, and it got pretty warm, and into the overheat portion, about 1/2 way on that part. and i didn't have the radiator fans on... I couldn't get out of traffic, so i pushed myself through (my blinker keeps burning fuses...) and i got out of traffic, down a road with no outlet (as posted) just to try to drive around and let my engine cool down... but i didn't realize i could just pull the cable and get it to pop the hood, i thought i need a tool to hold the outer sleeve because i've needed one before (the plastic hood popper housing broke)
my engine has been making those sounds after that traffic incident.
'82 928S
'85.0 944 Not Awesome - Being Parted Out
Old 11-09-2003, 12:12 AM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
a humming from the rear of the car can mean a worn fuel pump
get near the rear of the car while the engine's running (but try not to ingest too many exhaust fumes)... is the humming coming from the fuel pump (little cyllinder before the fuel filter on the passenger side of the rear of the car)?
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 11-09-2003, 06:26 AM
ds475's Avatar
well... i don't think it's my fuel pump, because i've heard my fuel pump run before/during/after said hum.
'82 928S
Old 11-09-2003, 11:48 AM
strange humming coming from my rear
Lay off the mexican food. Sorry, I couldn't stop myself.
If it is the fuel pump, was it hot outside when the noise started. Try venting the gas cap and see if that makes it stop. Not a permanent fix though.
'87 924S , sold.
'99 Subaru O/B, 62K on first timing belt. Could have gone another 40K.
Old 11-09-2003, 02:54 PM
vott does ziss do?
ronin's Avatar
as CJ said. it could very well be the fuel pump. the sound that you are describing is very similar to that when one is on its way out.
Old 11-09-2003, 03:01 PM
ds475's Avatar
hmm... i will inspect my fuel pump... are there any alternative fuel pumps i can use... like some generic kind, or do i need th oem pump? how much are fuel pumps?
'82 928S
Old 11-09-2003, 07:55 PM
ldl ldl is offline
ldl's Avatar
For your car...
Pump Prices & Resources
- Performance Products: [Bosch or Pierburg] Early 85: $199.95 , Late 85: $229.95
- Vertex Auto: [Bosch] Early 85: $159.00 , Late 85: $Same
- 9xauto: Early 85: $235.50 , Late 85: $Same
- Tweeks: Early 85: $159.99 , Late 85: $Same
- Pelican Parts: Early 85: $151.50 , Late 85: $Same
Hope it helps.
Later man.
85.0 944 Automatic
^ Bending my wallet over at every possible moment.
Old 11-09-2003, 08:19 PM
