-   -   Running the engine hard (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/135468-running-engine-hard.html)
rbt944 11-13-2003 11:59 AM
I used to keep the 944 at low revs all the time, never going beyond 4 grand. I felt as if it didn't have it in it to go beyond. One day went up to 6 and was surprised how smooth it felt in the higher revs. Not to mention the sound. I take it up into the fun territory every now and then, and the engine still runs good, if not better.
dj_yen 11-13-2003 11:59 AM
Originally posted by 944S Boyeee
That is what low oil lights are for, my good Sir.
I keep my oil a wee bit over the full mark, just incase!
Jeff (944S Boyeee)
isn't that potentially harmful also considering the additional oil pressure and all?
Dark Skies 11-13-2003 12:10 PM
Perfect!
Jeff (944S Boyeee)
Perfect horror would be if your passenger were to turn to you and say... "ya know when you were topping up the oil at that station a few miles back? I could have sworn you used windscreen washer."
Dark Skies 11-13-2003 12:16 PM
I shouldn't think a few mil over the full mark would make much difference. I'm sure Porsche gave a little leeway for filling mishaps. I think you'd need to have about a pint over before it'd have any ill - effect. Maybe more.
Dantilla 11-13-2003 04:29 PM
A word of caution-
The car will use more oil at high RPMs. On my old 944S2, I could drive for several weeks on the street and not lose a drop of oil. After a 30 minute track session, it would be time to add 1/2 a quart. This is normal, so check your oil every time you get back to the pits.
Manute 11-13-2003 11:43 PM
If i didīnt check my oil everyday,i should starve it in 100 miles...
adrian jaye 11-14-2003 01:04 AM
DS,
on Porsches,
They are ment to be driven. However some peoples definition of driven are different to others !
To get the best especially of you drive fast you need to get the rev's to the limit not forgetting to drive the car within its and your limits AND SAFELY
IF your car is properly maintained and serviced.
It is checked before each and every "hard driving session"
IF you are driving it to the limits, the relevant parts are upgraded or up to the job (and to Porsche Specs)
Then there is no problem. The Rev limiter will protect your car from any no brainers.
However the harder you drive a car the more wear you induce.
BEar in mind people who race cars on the indy circuit, race traksx & tracks days.
usually do a lot of work before and after a race. A total strip down/oil change after a race is standard sometimes.
bear that in mind
Road Driving "does not equate to" fast road/track/racing
