P944GUY's Avatar
Post tires
Help need tires '87 944 215/60/15 Fone dials
Old 07-24-2001, 08:45 PM
P944GUY's Avatar
Post
I've been doing some research, and if I get new rims 16 or 17's there's a lot to choose from. However, I'm sticking with the 15 fone dials for now. Has anyone found any Euro metric tires anywhere? you would know they are euro metric because there is no "P" in front of the tire size 215/60/15. Afew places have told me I need those because the rears are supposed to be at 36 psi. I cannot find any manufacturer with theses tires. I'm thinking of going with the Yokohama AVS Intermediate-there cheap, "V" rated, and they look good. About $76/tire. Tell me what you think--PS--don't tell me to get new rims. Thanks for your support
Old 07-24-2001, 08:53 PM
P944GUY's Avatar
Post
can I go with a little larger size and not affect speedometer say, 225/60 15 ???
Old 07-24-2001, 09:14 PM
Post
Boy, are you confused.
The P in front of the tire description stands for "Passenger", as in passenger tire, not Euro metric tire.
I suggest you go over to TireRack's site and read up on tires so you at least have enough knowledge to get into real trouble.
Old 07-24-2001, 11:59 PM
ae1969's Avatar
Send a message via ICQ to ae1969
Post
..I ran the 225/60/15 in the rear......for the longest time.....no problems.....just a slight change in overall tire diameter....but it is rather insignificant......shouldn't affect your speedometer at all.....
I finally switched to 17" rims.....and 225 in front and 255 in the back.....ouch.....it handles like night and day....with the 215 on 15 inch rims....it would just slide around the corners........but once I switched to 17....it was a BIG difference....
Kuhmo and Toyo.....are your best bang for your buck......
Alex
The love of my life.......
Old 07-25-2001, 12:02 AM
mideastmafia's Avatar
Send a message via AIM to mideastmafia
Post
how do you get bang out of a tire??
SHAUN
Old 07-25-2001, 12:35 AM
Post
Shoot It!!!
Old 07-25-2001, 04:47 PM
1.2gees's Avatar
Send a message via AIM to 1.2gees
Post
225/60/15s are a bit taller then stock.
If anybody manufactured a 225/55/15, that would be very close in diameter, but nobody does, so I chose what I believe(d) to be the next best thing, 225/50/15 in the front and 245/50/15 in the rear.
Although I drive my car hard, and will be racing it often (again...) I may stick to the original tire size, 215/60/15. I've tried everything from 255/40/17 to 225/45/17 to 245/50/15 to 215/60/15, etc. etc. Except for the occasional panicky stab at the pedal, there's not that much of a difference in all out grip. If you're not heating up the tires, wider tires will only add weight, make more noise, cost more, increase the chanse of hydroplaning, be less aerodynamic-->fuel efficient, etc. etc. Also, given that everything else is the same, stiffer the sidewall, the less warning you're going to get before the tires break away. 17 inch rims do reduce flex, but make the car much less forgiving, so be carefull.
Yoko AVS' are good tires, just don't expect them to last too long
Ahmet
It's all the driver...
My page over1g@hotmail.com
Porsche owners Gallery.../My 944
Old 07-26-2001, 05:14 AM
stray15's Avatar
Send a message via AIM to stray15
Post
Ahmet, they do make tires in 225/55/15. I have seen them in the tire rack review at work....I think anyways. I will double check.
Porsche, through and through
Tim
'83 944
http://community.webshots.com/user/strayer15
http://www.geocities.com/tstray15/Home.html
Old 07-26-2001, 05:31 AM
1.2gees's Avatar
Post
The very last time I checked at TireRack, the only tires made in 225/55/15 were competition (makes sense) oriented, or ultra high price ($230+ I think, compared to ~$70 Yoko AVS' that I can use to scare my DE instructor)!
Get back to me anyway though,
Ahmet
Old 07-26-2001, 05:34 AM
ae1969's Avatar
Post
uhmmm......my bucks....occassionally go BANG!.....everytime I have a problem with my car......BANG.....another one disappears (well more than one)
no one has had this happen???.....
...uhmmm ....I still think my 255's....keep the rear end where they are supposed to.....that is behind me....LOL.....
The only disadvantage it may be a little bumpier..I didn't actually notice it.....but frankly....I thought the ride would be worse....
Kumho and Toyo are so much cheaper than the others (at this size)......and they are actually pretty good tires......I thought they would maybe wear quicker....but they are holding up pretty good....and they feel much better than BF goodrich T/A that were on the car.......
Alex
Old 07-26-2001, 10:21 AM
