JH924S's Avatar
Send a message via AIM to JH924S
Exclamation oil by AFM
I took off the jboot? that goes between the throttle body and AFM and found a lil puddle of an oily substance and a film throughout the boot. what the crap is this from, bad piston rings? filter is ok. the film was oily and dark any ideas? this cant be good
1987 924S black on black , does it get any better?
Old 11-18-2003, 03:22 PM
meister member
speedracing944's Avatar
K&N filter oil with dirt in it? What type of filter do you use or have used?
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 11-18-2003, 03:34 PM
I'm off the hook.....
I have discovered that if any of the shaft seals (cam, either balance shaft, or even the crank) are leaking, the cooling airflow being sucked past the timing / shaft belts in the cover will end up in the bottom of the airbox, and eventually migrate to the throttle body.
You might look for a little puddle in the bottom of the airbox.
No, I don't sing. Based there for too long.
Old 11-18-2003, 04:43 PM
JH924S's Avatar
oh that def makes sense wilkey , thanks for the speedy responses guys
Old 11-18-2003, 05:38 PM
