Send a message via AIM to TheCooler
Chattering near flywheel/oilpan
Well while i was examing my voltage while the car was at idle and in neutral I noticed a stranger chatter at the bottom of my oilpan/flywheel area. The chatter sound isnt higher than the ticking lifters but it is still noticeable from about 5 feet away. It is very weird because it has a pattern to it. It chatters for about 3 seconds then stops for 1 then chatters for another 3 seconds and so on. I highly doubt rob bearings because mine were fine when I looked at them. I heard it could be an uneven flywheel? The PO had done a clutch job a little while ago. Could it be from him not getting the flywheel resurfaced? I have no idea if he did or didnt. I assume rod bearings would be a lot more noticeable and be constant rather then in a pattern.
-2002.5 GTI VR6 24V 6SPD
-Kalahari Beige 89 Porsche 944S2
-87 VW GTI 1.8 16v
-2007 Ford PIMP(free)star ...company car....
-1999.5 Jetta VR6
Old 11-18-2003, 07:49 PM
I'm off the hook.....
Could it be something loose in the flywheel housing?
I heard of a stone getting in there from the timing mark opening.
That is weird.......
Could it be something from the recent starter rebuild... one of the pieces you found loose in the starter? It is open to the flywheel from the back of the starter. Did it do this before the starter install?
I guess you could uninstall the starter again and look to see that the flywheel still has all of it's teeth.
That's one of those noises you'd want to track down.
Keep us posted.
No, I don't sing. Based there for too long.
Old 11-18-2003, 08:31 PM
I found 2 broken looking bolts that looked like a C after they came out where the flywheel meets the starter. I dont know whats up with that. But i think i had the chattering problem before the starter.
Flywheels teeth are fine from what i can see.
-87 VW GTI 1.8 16v
-1999.5 Jetta VR6
Old 11-18-2003, 09:11 PM
How long had it been making these noises? And I assume the noise has gone away now?
Wow, someone that had been in there a lot (experienced) might be able to figure out where they came from. Or you might try to look at a used or junkyard motor to see if you could match up the bolt. Otherwise, you might just forget it, and go on.
Could this have been the cause of the starter problem?
Did you get the connections all cleaned up so that the charging system is working again?
Old 11-19-2003, 07:00 AM
ae1969's Avatar
Send a message via ICQ to ae1969
You are sure they are not flywheel bolts.... post a pic
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 11-19-2003, 07:26 AM
SoCal Driver's Avatar
Could be bolts for the clutch.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 11-19-2003, 09:06 AM
ae1969's Avatar
oooopps yup thats what I meant to say.....
Old 11-19-2003, 09:20 AM
sorry i ment nuts before. I was tired, ill post picture of them in a new thread
-87 VW GTI 1.8 16v
-1999.5 Jetta VR6
Old 11-19-2003, 10:01 AM
ae1969's Avatar
Ohhhh... don't worry then. More than likely someone dropped a nut through the clutch inspection hole.
Old 11-19-2003, 10:03 AM
Broken ones?
-87 VW GTI 1.8 16v
-1999.5 Jetta VR6
Old 11-19-2003, 10:21 AM
I agree, the nuts look exactly like they were cut from a nut splitter.
Hopefully from a long previous job.
Old 11-19-2003, 11:12 AM
