Chris_924s's Avatar
Angry Headlights wont stay up.
Ok, it's getting darker earlier and I've noticed my headlights wont stay up. The slowly work themselves down until the motor kicks in and cycles the lights back up into the original starting position..
I recently noticed there are small rubber bumpers that have deteriorated (on the studs mounted to the wishbones on the headlights at the back of the bucket) anything there? They dont seem to rest anywhere.
Any Ideas?? The "No Driving lights" option is really bad..
TENSION YOUR SOCKS!
88 924S Guards/ Black ~ 10 years as a Daily Driver and STILL SMILING!
87 NA Diamond Blue Metallic ~ Gone
Old 11-18-2003, 10:01 PM
When my lights would not go all the way up I found the contact for the relay base were not making proper contact with the relay pins. Short cut I took was bending the relay pins inwards, and someone else on this board stripped the female lugs on the base and bent the portion that makes contact with the spade inward. Try this first before stripping the motor contacts.
Old 11-18-2003, 10:53 PM
scheistermeiste's Avatar
Send a message via AIM to scheistermeiste Send a message via Yahoo to scheistermeiste
hehe, your car has lazy eyes! does it have dark cicurls under its lights? if so it may just be tired....
Special Edition 924S 1988 <- SOLD!
Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker.
Old 11-18-2003, 11:28 PM
Chris_924s's Avatar
Originally posted by FR Wilk
Does the knob on the motor turn as the lights drop?
Yep. sure does. The entire mech is in sync. I thought about a loose nut (besides me !) on the motor but that's fine.
Viagra. I was wondering who would be first.. Thanks!
I have dark circles.. ever try driving at night when the headlights point at your front bumper??
I suspect a mechanical not electrical malfunction- i.e. a support or stay somewhere not in proper alignment- for the life of me I cant see one though.
TENSION YOUR SOCKS!
Old 11-19-2003, 11:47 AM
Chris_924s's Avatar
Can't the motor be rebuilt??
TENSION YOUR SOCKS!
Old 11-19-2003, 12:46 PM
Chris_924s's Avatar
Thanks - I'm gonna try a disassy on a non-working unit over the weekend to see if this is doable- I'll let you know if it's possible - I sure hope so..
TENSION YOUR SOCKS!
Old 11-19-2003, 06:05 PM
does it stay up when you do it manually....that will get you by in a pinch
1988 924s mars red
coastal cruzer
Old 11-19-2003, 06:31 PM
Chris_924s's Avatar
nope.. I'm pretty sure it's the motor. I will get a used one to try shortly. How does the gear assy come apart?
I had the entire motor out , pulled the rubber boot off the bottom and it looks as though it's all one piece.. I'm getting my PET back soon (I loaned it out..)
TENSION YOUR SOCKS!
Old 12-08-2003, 12:06 PM
