fast924S's Avatar
Send a message via AIM to fast924S
Porsche Crest Body parts question
Will 944 fenders directly swap onto a 924S, if not what kinda mods need to be done. I need the wider fenders because my 17,7.5 inch wheels rub, So I was thinking about swapping the fenders from my parts 944 onto my 924S, I know there will have to be some body work done to make it look clean. Alos how do the rear fenders come off are the welded in??? Thanx
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 11-23-2003, 09:56 AM
Wolf1's Avatar
Yes they will fit. No it is not a direct swap. The rocker panels are different. Yes they are welded on and difficult to remove. I just did this on my 931. It would be MUCH, MUCH, easier to get the carrera gt fiberglass rear flares. And probably cheaper if you consider all the labor involved to make the swap. The only reason I went with the 944 rear quarters instead of the flares is I REALLY, REALLY dont care for the fit and finish of fiberglass.
75 914 - Undecided.
80 931 - Gone, but not forgotten.
72 914 - old toy- sold.
And a whole bunch of German scrap metal shaped like 924's.
Old enough to know better, and stupid enough to do it anyway!
Old 11-23-2003, 11:44 AM
Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
You will also need a new front end valance to match the flare on the fenders as well as the rockers that flare out as Wolf stated. The rear has to be cut around the C pillar to remove rear fenders. Or go with Wolfs idea of GT flares which just cover the oem fenders and are open ended looking from behind. Sman
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 11-24-2003, 08:58 AM
SoCal Driver's Avatar
Just buy a 944.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 11-24-2003, 09:13 AM
Verruckt's Avatar
Who need them stinkin flares anyway? J/K
If you ever plan to autocross/roadrace/PCA DE event, you might want to check their rules first. You might get booted into a class where you are not going to do well...
The crashes people remember, but drivers remember the near misses. – Mario Andretti
1991 944S2 Rally #951 Rally-America.com
Old 11-25-2003, 10:24 AM
924Sman's Avatar
Absolutely!!! PCA the car can not have any body mods except for the front bumper area. Airdams, FG nose are the only allowed changes provided the new stuff doesn't reduce stock minimum weight. Steel fenders must be used, you can use 944 fenders on a 924 and be legal. Any other fiberglass used is most likely placing the car in GT class.
Just a note for those who consider tracking PCA CR.....Sman
Old 11-25-2003, 10:48 AM
