elvisizer's Avatar
Unhappy icu replaced, now the S won't start at all . . . .
My '87 S was having ignition problems recently- the engine would cut out momentarily sometimes, even under WOT. I stopped driving the car and ordered a replacement ICU (ignition control unit) on the advice of rennlisters. So, the car stayed parked for about a week until the ICU showed up. I took the old ICU out, and put the new one in. Now the car won't start at all. It turns over, and I can eventually smell fuel, so the DME relay is functioning, but the engine never fires. It does cough a bit now and then, but it never even comes close to firing up. Which is strange, because even when it was having the ignition problem, it still always started on the first try. I did try putting the old ICU back in, but got the same results as with the new one.
Now, I'm kinda worried i might've messed up the plug that connects to the ICU- is there anyway to check if i have? It was REALLY hard to get the plug off of the old ICU, and i think some retaining tabs on the plug may have been torn off . . To check if it was a loose connection causing this, I tried wiggling the plug around on the ICU while a friend turned it over, but there didn't seem to be any relationship between the splutters and any particular position of the plug. . . Any advice on what I could try next?
thanks in advance . . . . .
elvisizer
Old 11-20-2003, 04:43 PM
AFJuvat's Avatar
Well, what did you try before swapping the DME (ICU)? It is also entirely possible that the new DME is bad as well - put the old one back in and see what happens.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 11-20-2003, 05:57 PM
SoCal Driver's Avatar
Mike, He must have a 944S as this is the ignition control unit that mounts on the fender and interfaces the DME to the coil.
Me thinks that the connections are whacked.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 11-20-2003, 07:56 PM
elvisizer's Avatar
AFJuvat
I did put the old ICU back in- same results as with the new one . . . . won't start at all. which makes me think it's now a wiring problem, since it used to start with the old one- it just wouldn't run very well. but it did start.
elv
Old 11-21-2003, 08:48 AM
Could also be an alarm problem.
Old 11-21-2003, 11:47 AM
Are you getting spark?? It is not unheard of for coils to fail on these cars and it could be a coincidence that it failed completely when you switched the DMEs. Also, without the tabs on the DME connector it's possible you could have pushed a couple of the connectors out of the plug.
Good Luck!
Pat
87 944S Black/Black Club Racer
87 944 Kalahari Beige/Brown Daily Driver
82 911SC Platinum Metallic/ Brown Garage Queen
Old 11-21-2003, 12:04 PM
elvisizer's Avatar
no dme's involved here- this is on an S, so i'm talking about the ignition control unit that's just below the coolant reservoir on the driver's side front wheel well.
pm9146- i'd like to check that, but i'm not sure how to get the spark plug connector off the plug . . . . Can you tell this is my first attempt at working on the S?? anyway, do i just pull it off? I gave one an exploratory tug, and it didn't seem to want to come off. . . . .
Old 11-21-2003, 01:53 PM
Send a message via AIM to TheCooler
Pull.
-2002.5 GTI VR6 24V 6SPD
-Kalahari Beige 89 Porsche 944S2
-87 VW GTI 1.8 16v
-2007 Ford PIMP(free)star ...company car....
-1999.5 Jetta VR6
Old 11-21-2003, 02:03 PM
elvisizer's Avatar
thanx, cooler. i'll pull harder when i get home from work . . . .
Old 11-21-2003, 02:22 PM
Take the ground off of the battery for about 20 minutes. Supposed to reset the DME. Yes I know you replaced the ICU but try this anyway.
Old 11-21-2003, 04:16 PM
elvisizer's Avatar
i'm pretty sure the DME is functioning since i can smell fuel after a few seconds of cranking the engine, but i'll give such an easy fix a try anytime . . . .
thanx, socal . . . . .
elvisizer
Old 11-21-2003, 04:35 PM
The power to the ICS Ignition Control Stage and to the coil come from the same pin on the connector in the engine compartment.
This goes to pin #4 on the ICS and connection #15 on the coil.
Both wires look like they are black.
The ICS has a green wire that goes to the other pin on the coil. This is the "trigger" wire to fire the coil. Both connections are on pins #1.
The sheilded trigger wire from the DME goes to pin #5 on the ICS.
Pin #2 on the ICS goes to ground.
So with the key on you should be getting 12 VDC on pin #4 on the ICS and connection #15 on the coil.
Just a though have you checked that the HV wire from the coil to the dist cap is intact? Not pulled off of the connectors inside the weather boots?
Old 11-21-2003, 06:12 PM
