ds475's Avatar
Send a message via AIM to ds475
Oil Pressure Jumps
my oil pressure used to always stay at around 3 bar at idle, and .5 more during acceleration.
my oil pressure one day started working its way down little by little each day to 1.5 bar. then, this morning i start my car and it was a little bit below 2, and it stayed there for a wile. then i look back at my oil pressure a little later in my 10 minute journy when i'm on the highway almost to work, and it's at a hair above 4.
what in the hell? why does the oil pressure jump around like that? i haven't seen it INCREASE, it's only been decreasing.
does the oil pressure sending unit ever get messed up? or maybe it's my gauge?
'82 928S
'85.0 944 Not Awesome - Being Parted Out
Old 11-21-2003, 07:31 AM
Autobahn Garage
check the grounds, and also there is a article on the tech section of this board that talks about this very problem,Good Luck
T Tanner
76, 911s w/ Webers
76, 914/4
57, Speedster
Old 11-21-2003, 08:06 AM
Send a message via AIM to TheCooler
Also, check the wires going to the oil pressure sending unit. Ive found that the casing can become cracked and ground out sometimes.
-2002.5 GTI VR6 24V 6SPD
-Kalahari Beige 89 Porsche 944S2
-87 VW GTI 1.8 16v
-2007 Ford PIMP(free)star ...company car....
-1999.5 Jetta VR6
Old 11-21-2003, 08:53 AM
Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
How is the oil level? I doubt it is the sender as they usually "peg" the needle to 4-5 bar and stay there. Could be the oil pressure relief valve is hung up. On a sad note......oil pump....Sman
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 11-22-2003, 09:49 AM
Send a message via Yahoo to Cebu
Check the site below...I suggest removing the Oil Pressure Relief Valve Cleaning it up and re-installing it. Worked for me.
http://64.226.197.185/Paragon/Tech/944_oil_pressure_relief_valve.htm
85.5 944na
Automatic
V-65 Magna
94 Impala SS
Old 11-22-2003, 02:13 PM
