Key button
There is a button on the little thingy above the shift knob... you know where like the sunroof button and the back windshield button is. Ok but this button has a little Key on it, and you can push it down and stuff. Does anybody know what this is?
I'll get a pic tomorrow... but maybe somebody might know without a pic
86' Porsche 944 N/a
Old 11-21-2003, 08:18 PM
will944's Avatar
Send a message via AIM to will944
Power Lock Switch
10 E92 M3
13 Jeep GC Limited
98 Jeep Cherokee
87 951
C3 Stingray
Old 11-21-2003, 08:55 PM
its powered doors... it dosent work for some reason
86' Porsche 944 N/a
Old 11-22-2003, 01:28 PM
Send a message via AIM to TheCooler
Check the fuse.
-2002.5 GTI VR6 24V 6SPD
-Kalahari Beige 89 Porsche 944S2
-87 VW GTI 1.8 16v
-2007 Ford PIMP(free)star ...company car....
-1999.5 Jetta VR6
Old 11-22-2003, 01:52 PM
checked it, its fine
86' Porsche 944 N/a
Old 11-22-2003, 01:53 PM
will944's Avatar
Take the door panels off. When pressing the lock button you will see the power lock mechanism move in and out (rubber boot with a 4-5 inch white plastic rod connected)
Make sure that the white piece of plastic from the power lock mechanism is connected to the door lock shaft (vertical metal piece coming directly from the handle). There is a small knob on the door lock shaft that the white plastic piece connects to.
Press it on and the power locks should work.
10 E92 M3
13 Jeep GC Limited
98 Jeep Cherokee
87 951
C3 Stingray
Old 11-22-2003, 05:10 PM
vott does ziss do?
ronin's Avatar
....and the red light should come on
Old 11-22-2003, 10:45 PM
the red light on it does come on, its always on, except when i push the thing nothing happens
86' Porsche 944 N/a
Old 11-22-2003, 11:30 PM
vott does ziss do?
ronin's Avatar
ahaa, perhaps faulty switch. replace with a good one to see what happens. these switches can sometimes be "fixed" by opening them up, cleaning the contacts and making sure all parts are intact and not broken
Old 11-24-2003, 01:50 AM
will944's Avatar
Yeah...check the switch first.
Then check and see if the power lock mechanism is even hooked to the door handle like I said. If it's not those two...I have no idea
10 E92 M3
13 Jeep GC Limited
98 Jeep Cherokee
87 951
C3 Stingray
Old 11-24-2003, 10:38 AM
ae1969's Avatar
Send a message via ICQ to ae1969
....Check the switch on the dash but once you have wasted all your time looking for the cause it will more than likely be a faulty microswitch at the doors................ I HATE THIS POWER DOOR SYSTEM.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 11-24-2003, 10:52 AM
