-   -   Location of temp guage sensor? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/13720-location-temp-guage-sensor.html)
idopps 08-01-2001 06:33 AM
Hey, I removed the plate under my engine and found a sensor with a set of temperatures on the side of it, and two wire adapters. Well, I searched and found one already put in the top of the radiator. So, I thought the dealer was just replacing it and accidentally dropped it and decided not to get it out of the engine guard. My temp guage suddenly quit working, and someone told me that there were to sensors for the system. One in the radiator (which I can see), and the other for the guage. However, I just can not seem to find the dang place to screw the sensor that I found in. Anyone know specifically where to put it? Thanks from the Porsche rookie!
3sonfather 08-01-2001 08:53 AM
There is an engine temperature sensor located just to the front and below the throttle body. I believe this is the one your cabin gage is reading. The one on the radiator is looped into the radiator fan.
Scott K
