Porsche Crest S2 pinion gear removal
Does anyone know how to remove the 2nd gear from S2 pinion? The manual says "just press it out", but in reality a 20 ton press couldn't shift it even a little bit! There must be some trick... Maybe it has some additional circlip between 2nd gear and synchro hub not shown on the diagram... but in that case the manual is wrong.
Thanks in advance!
'91, S2
'85, 944
Old 11-26-2003, 07:35 AM
SoCal Driver's Avatar
Check the factory manuals on transmission repair.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 11-26-2003, 09:42 AM
That's the problem - I do as the repair manual says, but the 2nd gear is not comming out...
'91, S2
'85, 944
Old 11-26-2003, 11:22 AM
