Intake Manifold Cleaning
Another newbie question on my daughters 85.5 944. The clouds parted and my daughter and I went to work on changing out the timing and balance shaft belts. Along the way I pulled the air meter (MAF sensor - I'm not sure of the Porsche terminology for it), the intake boot, and ultimately the throttle body.
Here is the throttle body.
The back of the throttle body looked a little better but the intake manifold is, shall we say, "less than pristine".
I am certainly open to suggestions for a method of cleaning the intake manifold.
Oh, I put my daughter to work on cleaning the throttle body and she did a decent job of it.
She was going after it with a toothbrush and got a big spray of carb cleaner in her eyes. I'm amazed, she was calmer about it than I was.
The "T" line that ties to the intake boot, just before the throttle body is just about as crapped out as the throttle body itself with gunk. What is that line, PCV?
Lastly,
Does anyone want a set of original - real brittle - 1985 power steering and alternator/AC belts with the Porsche logo and part number printed on them? They look cool but they are big time shot.
Thanks,
...Lee
Old 05-11-2007, 08:03 PM
winter-hater club member
nynor's Avatar
i see the irresistible fingernail scrape through the goo.
"COOL PRIUS!" - Nobody Ever
Old 05-11-2007, 08:15 PM
idesign635's Avatar
Send a message via Yahoo to idesign635
I just cleaned the intake on my 968. I removed it from the car and used carb cleaner with brushes on the inside. The soaked the inside with degreaser and hosed it out.
When I removed the intake, the intake ports on the head were just as bad as you throtthle body maybe even worse. I very carefully cleaned them using carb cleaner and lots of rags.
Make sure the valves are closed brfore doing this. You don not want any carbon crumbs in the pistons.
94 968 Polar Silver/Black, LSD, 6 speed, Short Shift, Kenesis K58's, Adjustable Konis, M030 Swaybars, Dynatech Strut Brace, Design 1 Racing Lower Strut Bar, Air Box Mod, B&B Catback, RS Barn Chip, Big Reds
86 951 Black/Black Lindsey 3" Exhaust, Lindsey DP Wastegate, Lindsey Black Knob, 3 Bar FPR, MaxHP Chips
Old 05-12-2007, 06:34 AM
