andrew4266's Avatar
Question clutch fluid low
The brake fluid reservour got low enough to point that the clutch had no pressure. I filled it back up but I still have no pressure. Is there something else I need to do?
Old 08-02-2001, 11:05 AM
el Diablo
Guest
Posts: n/a
Post
find and fix the fluid leak, then blead air from system.
Check for leak at clutch slave cylinder and at brake master cylinder. Possible leak at firewall visible up under dash where brake rod go's into firewall. If it's wet, fix it.
Old 08-02-2001, 11:18 AM
