Question Tail light seal/gasket
I have just repainted my 1984 - 944. The tail lights had a black stickly puddy like sealant used as a gasket around each tail light lens. Can anyone tell me what this sealant is called , a part number, or where I can obtain some of this sealant material.
Thank you
Paul
Old 11-28-2003, 03:10 PM
AFJuvat's Avatar
Just use black silicone
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 11-28-2003, 06:29 PM
Roger Hall's Avatar
I got some to reseal the blower motor cover on my 81 N/A at the local auto parts store. Its called ribbon gasket and it it used to seal windsheilds.
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 11-28-2003, 07:38 PM
See this thread ... mentions the NAPA part number for the ribbon gasket stuff ...
Tail Light Assembly Removal
84 944 5spd
Maint. & Fixes made thanks to the help received on this board:
Rear Hatch Pins, Oil Change, Dash Cover Installation, New Rear Seat, New O2 Sensor, New Ignition Switch, New Fuel Pump Relay, Rear Light Assembly Reseal, Instrument Panel Short Circuit, New Speedo Cable, New Timing belts and Starter.
Old 11-30-2003, 09:21 AM
I got some sealant from a Porsche body shop for the rear lights. The manufacturers are called Wurth and the part number is 890-100-032. It came on a roll, was black and about 12mm diameter.
944s2
Old 11-30-2003, 01:37 PM
Did you seperate the lens from the housing, or did you take the whole assemly out. If you did, just use black silicone.
86 944 daughters
88 944 step-sons
07 Ranger 4x4
I have tons of spare parts, let me know what you need.
Old 11-30-2003, 05:14 PM
It is my understanding that the black ribbon gasket sold specifically for this purpose is 'non-hardening' thus allowing one to more easily remove the lens later should further repairs be required.
Is black silicone also a non-hardening sealer?
84 944 5spd
Old 12-03-2003, 06:29 AM
