Where is the Heater Fan Resistor Pack??
Just need to know where to look... Fan running only on high and not the other speeds... Likely this is the problem I just need to find it.
It is a late 944 with the auto climate controls Aaron
Look under the black plastic cover on the blower fan.
You will see a cable attached to an oval shaped piece held in with two screws. - disconnect the cable and remove the screws - voila - one resistor pack. Hint: soak the resistor pack in white vinegar - it removes the corrosion - if the resistor isn't too far gone, it will bring it back from the dead. Resistor pack is a dealer only part - they run about $174. AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
Gads! $174...
A $5 SCR is looking real good.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
