-   -   Where is the Heater Fan Resistor Pack?? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/137584-where-heater-fan-resistor-pack.html)
asudds 11-28-2003 08:13 PM
Just need to know where to look... Fan running only on high and not the other speeds... Likely this is the problem I just need to find it.
It is a late 944 with the auto climate controls
Aaron
SmileWavy
AFJuvat 11-28-2003 08:17 PM
Look under the black plastic cover on the blower fan.
You will see a cable attached to an oval shaped piece held in with two screws. - disconnect the cable and remove the screws - voila - one resistor pack.
Hint: soak the resistor pack in white vinegar - it removes the corrosion - if the resistor isn't too far gone, it will bring it back from the dead.
Resistor pack is a dealer only part - they run about $174.
AFJuvat
SoCal Driver 11-28-2003 08:49 PM
Gads! $174...
A $5 SCR is looking real good.
