-   -   CR-1 radio security code questions (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/137770-cr-1-radio-security-code-questions.html)
sboggs 11-30-2003 05:44 PM
I'm installing a CR-1 radio in my 93 RSA and am having a problem with the security code. This is the same radio installed on many 924/944. I assumed the code would be some combination of 1-6 corresponding to the radio preset buttons, but the code the dealer gave me is 3083. They said you push the first button 3 times, the second button zero (or 10?) times, the third button 8 times and the fourth button 3 times. I can't seem to get this to work and the manual is not very clear.
Can someone confirm this is the proper way to enter the security code? Also, I have the radio hanging out of the dash until I know it will work. There is a micro-switch on the top of the unit. Does this need to be depressed to allow the code to be entered?
944 boy 11-30-2003 05:51 PM
This radio was installed in 968's and early 90's 911's. I dont know why the method described diddnt work. Thats how i thought coded Blaupunkts worked. Try the microswitch.
