repoman's Avatar
Question car in lay-up, new belts, when do I check
I did belts in Sept, 300 miles, now in winter lay-up. It gets started once a month for 30 minutes.
Once Spring rolls around car won't be driven much as I'm taking my time on restoration.
So, the question is, when should I check belt tension again? I'm thinking March, 500 miles since change. Or is this to early?
'84 944 auto stock
Old 12-01-2003, 10:34 PM
Manute's Avatar
I can extend the question if you donīt mind...What is the timing belt procedure?
You change them,then you retension it at about 2000 miles,then,assuming you run the car at, say once a week,what do you need to do then? Can you wait till the next timing belt change,at about 40k miles more?
85ī5 951
Old 12-01-2003, 11:40 PM
repoman's Avatar
Just to be safe, I'll probably retention in Mar/Apr (800mi)
'84 944 auto stock
Old 12-02-2003, 09:28 PM
