TCMdocs944's Avatar
Cool Battery Box Fix-Pics/write-up
My peskey "mysterious" water in the rear passengers footwell led me to investigate the PO's battery box "fix" and my (embarassed) dynamat "fix" over the top of that..
First the Dynamat.....not the best of my ideas...Then
When I pulled up the poorly mixed fiberglass resin and the old license plate the PO used as a patch
Here's what I saw
Be Afraid....
Yes, that's right...Look closely to see my passengers carpet.....
Undaunted, just a little pissed, I start my repair..
Materials - Por-15 starter kit, thin guage aluminum, tin snips, stainless 1/4 inch screws, wire brush and a sharpie. $30us total.
Cut the metal to size and beat in the shape of the battery box
Prepped and cleaned area according to Por-15 instructions....
Pre-drilled screw holes in aluminum after marking with sharpie...POr-15'd it..
First coat of Por-15.....Then Metal with screws ...then Por-15
Two more coats of Por-15... careful to seal all edges and screws..
Big thanks to KurtV on the 911 board for leading me in the Por-15 direction....I would coat the whole car with the stuff if I could
...Just kidding.
Hope this helps you guys fix that leak once and for all!
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 12-02-2003, 03:35 PM
ae1969's Avatar
Send a message via ICQ to ae1969
HOLY CRAP.
NOW THATS A HOLE
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 12-02-2003, 04:38 PM
TCMdocs944's Avatar
Moral of the story ----"Do it right the first time"
Old 12-02-2003, 04:42 PM
vott does ziss do?
ronin's Avatar
JAYSUS! that before pic looks like the autopsy of Yul Brynner's lungs! very nice fix! is the POR-15 good for exterior type applications as well?
Old 12-02-2003, 06:11 PM
SoCal Driver's Avatar
You need a catch for a hold down strap on the outside. The single bolt and edge clamp will not hold the battery.
Check out RV supplies. Can also find a main shut off for the battery.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 12-02-2003, 06:14 PM
Manute's Avatar
LMAO
85´5 951
Old 12-03-2003, 02:49 AM
Posted a link to this on Rennlist.
Check out the comments:
http://forums.rennlist.com/rennforums/showthread.php?s=&postid=911497#post911497
Ooo! A circular thread!
Old 12-03-2003, 08:04 AM
TCMdocs944's Avatar
Yeh, the Por-15 is supposed to work for exterior but the black will fade /not weaken in UV. I read about this after the fact in some Hotrodder books.
This stuff has a permanent place on my workbench.
SoCal - I am thinking of doing the battery relocation thing to the passenger rear well. Optima yellow. Just a litte worried about the corner weight thing. The factory hold-down for the battery is miserable not to mention exposing it to the rain.
Old 12-03-2003, 10:20 AM
vott does ziss do?
ronin's Avatar
I really think I've missed something here, but are you planning to run without a hood??
Old 12-03-2003, 11:25 AM
TCMdocs944's Avatar
Naw ronin.... Water from the windscreen on the 83 runs directly into the battery box area, usually on the positive terminal. I somehow don't really like that idea. I wish P had put some kind of peice between the hood and the windscreen for drainage..(hmm, may be my next fabrication attempt)
I am seeking to keep my electricals clean, healthy and dry....every little bit helps.
Old 12-03-2003, 01:02 PM
vott does ziss do?
ronin's Avatar
ahaaa. so that's what those metal plates under the rear edge of my hood are for (along with the plastic that channels the water away) looks like they did make the change you wanted later on
Old 12-03-2003, 02:25 PM
Still have the stock plastic cover on my battery. Do need to pull the battery and reseal the area.
Rust Never Sleeps.
Old 12-03-2003, 03:11 PM
Manute's Avatar
Are your plastic cover well fitted,screwed,or something that keep it in a place?I think mine´s the stock one,but doesn´t seems too good,it covers strictly the battery and it is loose without any screw.And i think water can go to the battery place too easily with not very heavy rain.
85´5 951
Old 12-03-2003, 03:21 PM
Nobody Special
gobogie's Avatar
hmmm
PCA Member - Zone 4
Michiana Chapter
'86 944 Guards Red/Black Leather (Sold)
'89 951 Guards Red/Black Leather 69K (Winner Best Stock 944 Turbo - 944Fest 2005)
www.autos.groups.yahoo.com/group/CorysPorschePage/
Rennlist: "GOBOGIE"
Old 12-03-2003, 03:30 PM
TCMdocs944's Avatar
Seems like Porsche assumed on the early cars that if you could afford one you probably had a garage....
Does the later plastic fit on the early cars.?...I would love some rain channels up there.
Old 12-04-2003, 09:44 AM
vott does ziss do?
ronin's Avatar
probably not, the bottom of the windshield is different
Old 12-04-2003, 10:21 AM
