Help!
A mouse ate through a small solid hose next to the battery in my 1989 944S2. There is a kind of reservoir (black can) next to the battery, and a flexible piece of hose comes from it. Inserted into that hose is a VERY thin piece of plastic tubing that goes past the battery and plugs into a larger flexible hose to the engine. I have no idea what this hose is for, but the mouse ate the solid and thin piece! Is there anything in this thin hose other than a center hole? I need to replace it. At present the thin, hard piece is chewed off and seems to be sealed, so the engine runs fine. but, there must be a small leak in it somewhere. What is this small plastic tubing called and is there a part number? What is this vacuum reservoir part of and why is it here? P.S. I also lost my right low beam headlight. There is no current to the yellow wire at the headlamp. The mouse must have gotten a cable somewhere (the ground is also gone on the right headlight). Any clues where to look? I took off the engine covers and searched around the front of the car, but saw no obvious mouse damage. The ground is easy, but can I run a new yellow wire from the fuse box??? Darn Mouse! Report this post to a moderator | IP: Logged |
Gon fix it with me hammer
i'de say buy yourself a cat !!
just make sure it ain't a sleep somewhere on a wheel before your drive off... vroooomweeiiieiaiaiiaiiaflopflopflopflop
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
I don't need a Jaguar -- I've got 2 Porsches! But, I do need a vacuum line. |
Where is the battery on your S2 because mine is at the back of the car...
Maybe you could post a pic for reliable diagnosis...
(x)'89 944 S2 Cabriolet (Guards Orange) : ( )'90 944 S2 (Maraschino Dead!) : ( )'89 Audi 90 Quattro 2.3 20V : ( )'92 Renault Clio 1.4 : * |
Let's go shooting.
1983 944 Lux (manual) 2.5 litre 8 valve na and no pas 1991 944 (automatic) 2.7 litre 16 valve na and pas "I have only five words for you: From my cold, dead hands." Last edited by Dark Skies; 12-03-2003 at 10:26 AM.. |
Finally that criminal is caught!
...............Get some justice Darkskies or maybe just mail him to Midwestshooter and let him do it!
83 944 white w/Boxster wheels Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Certified Rennwerker
May be the vacuum reseviour. Does the canister have a domed top and mounts on the firewall? If so the tube eventually ties into the brake booster. On the booster there is a small valve with a plastic tube connected. See if that tube matches.
For every mouse you kill there are a dozen waiting to take it's place!! Sman
PCA " I've been everywhere, done everything......just can't remember any of it!"
Ouch,another guy lost the speedometer hammster...
![]() "Hey there, Hi there, Ho there, you're as welcome as can be! Now's the time to say goodbye to all your vacuum lines... F-U-C-K-I-N´ M-O-U-S-E!... F-U-C... (See ya real soon!) K-E-Y... (Why? Because we love you!) M-O-U-S-E..."
--------------------------------------------- 85´5 951 |
But--why the short piece of hard platic tubing? Is it to keep the battery acid from destroying the hose??? Whatever, the mouse loved it! I bought 10 traps today! And a box of mothballs. Dick |
Please keep us informed about the hunting.Wilk has some nuke heads if you need them.
Plastic is less prone to oil ruining it or collapsing. Where in Iowa are you? I am in WDM.... Sman
Dick |
Let's go shooting.
1983 944 Lux (manual) 2.5 litre 8 valve na and no pas 1991 944 (automatic) 2.7 litre 16 valve na and pas "I have only five words for you: From my cold, dead hands." |
