TCMdocs944's Avatar
Am I missing something here?
My front side marker is kind of "floppy" on the right side i.e. doesn't really seat very well....really loose. When I pulled the one on the drivers side it was tight and seemed to have the remnants of a gasket or something that held it in....
What gives?
Can a new seal be purchased without buying the whole light?
Or, do I just make one...
Or, was nothing there in the first place...
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 12-03-2003, 10:45 AM
AFJuvat's Avatar
You are missing a seal that is unfortunately, not available as a seperate piece.
You could fashon one out of some rubber without too much difficulty.
You could be missing a few of the knurled nuts that hold the light in as well - there are two per light. If yours are gone, you can just use a M5 nut with a large washer.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 12-03-2003, 08:41 PM
SoCal Driver's Avatar
You can make the o-ring seals. Buy a length of the proper diameter stock and cut it to length then glue the ends together.
I'll check with the local seal shop for cost if someone can measure a seal for me. Need OD and over all length.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 12-04-2003, 09:34 AM
TCMdocs944's Avatar
Yeh, I've got the knurled nuts still in place,..that was the confusing part. The seal was so bad that the R was totally gone and the left looked like dirt or wax buildup.....Def. not a seal.
You could probably "heat seal" the ends together with a lighter.
Looks like fabrication time.
I'll probably make it out of the same rubber I made my timing belt with.
Old 12-04-2003, 09:39 AM
No you don't heat seal butrate rubber. You glue it.
I'll try to get out to the garage and see if I have any of these o-ring seals to measure.
Old 12-04-2003, 09:41 AM
