TCMdocs944's Avatar
Early Spoiler warpage repair started....
I just picked up the latest copy of Grassroots Motorsports and they had a great artical on fabricating component brackets out of thin metal....Idea is you put a "break" or "lip around the edges for strength.
Looks easy enough so here I begin......
Made a form out of two peices of wood screwed together..
Hammered the lip with repeated light passes
Filed the edges...............then
I am putting three new stainless bolts on each side sandwiching the plastic between the existing metal bracket and my "new" brackets....
I was amazed at how strong the peice of metal became with the addition of the break....Very easy to do too.
More pics and writeup to follow
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 12-03-2003, 09:53 AM
TCMdocs944's Avatar
BTW - I started with 26g galvanized cut in 1.5in strips with tin snips. Put it between the two peices of wood "form" then tightened the screws.
Old 12-03-2003, 09:56 AM
Friend of Warren
TCM, I like your inventiveness!
Kurt V
Old 12-03-2003, 01:15 PM
TCMdocs944's Avatar
I get a kick out of learning new things. I will usually try it and decide whether or not to "farm it out" the next time. HotRodders/restorers always do some neat stuff.....
I know KurtV probably knows from the cars in the sig line...
..........I am sure you can't just go to the parts store and pick up parts for the Austin.
I like to make sure things are really broke before I pitch em'. Same problem will usually happen to the new one eventually.
Old 12-04-2003, 08:50 AM
thamlin000's Avatar
Really cool. There is a lot of 944s out there that need this done.
I'll look forward to updates and the final results.
The present: 83 944, 77 911S
The past: 95 911, 67 912, 76 912E
Old 12-04-2003, 04:13 PM
TCMdocs944's Avatar
I will post the whole thing whether it turns out or not. I have just started to bolt the metal in ....very strong and almost no weight. I am probably going to have to heat the center a bit.
I have high hopes so far...If all else fails I will fab. another piece for undernieth the warped portion. I think this may bring it back in line though.
Old 12-04-2003, 04:42 PM
TCMdocs944's Avatar
Update
Materials - 6 stainless 10mm bots and nuts
Warpage from the back
Bolts in place but not tightened yet...Straigtening nice huh?
Old 12-05-2003, 08:47 AM
TCMdocs944's Avatar
Right now it is sitting on strategically placed blocks so that the lengthwise crease in the spoiler opening is regaining its sharpness.
I think I will have to apply heat to it though.
Fixing the cracks around the front
Yes, I fused them with a soldering iron...Am going to sand and fill with epoxy I think....
Here it is from the front......getting better as I speak..
Daughter wondering "why daddy car in kitchen?"
More to come.....
Old 12-05-2003, 09:00 AM
Great idea - I just happened to be reading "Grassroot Motorsports" last night and saw the same article on how to fabricate brackets. I was planning to fabricate an aluminum fan shroud for my TR6.
Stay Posted - more to come.
Old 12-05-2003, 09:28 AM
TCMdocs944's Avatar
I was amazed at how easy the fab process is and how great /strong/light it turns out.
Must admit though that I have had this burning urge to work with metal for some time... i.e. welding and sheet metal fabrication on a large scale..
Old 12-05-2003, 09:44 AM
ae1969's Avatar
Send a message via ICQ to ae1969
Cute daughter.... I have a couple of rug rats myself....
Project is a great idea....
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 12-05-2003, 11:14 AM
