andrewgoh's Avatar
Angry Baby Down....Need Urgent Help!!!
I was not able to start the 84 944 NA daily driver for the past couple of weeks (resorted to driving the 951):
1) There was no electrical power current whatsoever (no lights on the dash, starter would not crank).
2) I assumed it was a weak battery
3) I bought a portable jump start battery today and attempted to jump start it:
http://www.partsamerica.com/PartDetails.asp?SourceArea=&SourcePage=SEARCHRESULTS&MfrCode=CPM&MfrPartNumber=PMJ8960&CategoryCode=3014
4) Used the recommended jump start procedure:
positive to positive; negative to ground
Still no electrical power current whatsoever (no lights on the dash, starter would not crank). I hear frequent posts about similar problems due to a faulty DME relay or DME unit. Can anyone help me with these questions please?
1) I checked the early 944 layout diagrams for the relays:
2) I do not see a relay for "DME relay". Would this be the "fuel pump relay" as shown in the pic in the link above?
3) How do I remove the relay....do I simply pull it out gently?
4) Could a faulty DME unit also be a cause?
5) Any other possible causes?
I would appreciate any advice on the steps for diagnosing the problem.
THANKS!!!
Old 12-03-2003, 03:54 PM
thamlin000's Avatar
I had the same problem a few months back. It turned out to be a defective battery. The kicker was that the battery was one month old. Needless to say, I exchanged it for another one and the car was fixed.
Either test the battery or take it to an auto parts store and they'll test it for you.
Check, clean and tighten the grounds too.
The present: 83 944, 77 911S
The past: 95 911, 67 912, 76 912E
Old 12-03-2003, 04:05 PM
SoCal Driver's Avatar
Absolutly no electrical in the car means that there is a big gap between the battery and the rest of the car.
Start checking the wires at the battery both large and small.
Usually it's the ground straps that cause most of the problems.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 12-03-2003, 04:08 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
Very rarely does a battery just go bad. A lot of shops will replace the batt. first because it's an easy r and r, and when it turns out to be something else they can con the owner that problem B caused batt. prob. A when this just isn't the case. However, the connection between the cells of the batt. sometimes do disconnect, or the lead between the cells and the posts. Have you arced your posts? Do what Hugh sez and check your grounds and pos. connections first. Then if nothing helps (firstly first check voltage at batt.) look into replacing your batt.
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 12-03-2003, 05:43 PM
Electrical problem mantra on European cars...First Check All The Grounds. Even if it doesn't sound like a grounding problem, it's a 50/50 chance it is a ground problem.
Have you (or anybody) done recent work on the car? Check the work and see if they forgot to properly reattach a wire/fuse/relay/etc.
-Dave-
1969 911/3.0l SC
Old 12-03-2003, 07:19 PM
AFJuvat's Avatar
The DME relay is the fuel pump relay and yes, you just pull it out.
As the others have said, you have an electrical issue, not a DME relay problem.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 12-03-2003, 08:59 PM
andrewgoh's Avatar
Guys, thanks for all your pointers. I'll check the car out again this weekend, and keep you posted!!!
Andrew
Old 12-03-2003, 10:56 PM
andrewgoh's Avatar
Here is the conclusion....
It was a totally dead battery...registered at 2.4 amps... so dead that the portable jump start unit was of no help....
I replaced it with a new battery, and it started right up.
Unfortunately, I was hit with another gremlin....one of the rear tires went flat on me....there is a huge nail that has taken quite a liking to the poor ole tire.
Time to replace all four tires anyway! Thanks to everyone for your help!
Andrew
Old 12-06-2003, 04:00 PM
thamlin000's Avatar
good to hear and sorry to hear.
i got a sidewall puncture less than a month after installing my new yoko avs es100s on my car. extra $100 gone.
Old 12-06-2003, 05:27 PM
