todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
sealant
What is the recomended sealant to use in conjunction with a new oil pan gasket?
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 12-03-2003, 10:23 PM
vott does ziss do?
ronin's Avatar
none according to Haynes. FWSM says..... (brb)
Old 12-03-2003, 10:34 PM
vott does ziss do?
ronin's Avatar
.....none "check, replacing if necessary"
Old 12-03-2003, 10:51 PM
Verruckt's Avatar
Are you replacing your oil pan gasket on your 944 or your 951? I have heard the job sucks. Of course it is next on my need to fix list. Post your pics and write your story. We all like todwic stories. ;-)
The crashes people remember, but drivers remember the near misses. Mario Andretti
1991 944S2 Rally #951 Rally-America.com
Old 12-04-2003, 01:54 AM
vott does ziss do?
ronin's Avatar
good question, forgot that cowman has both
Old 12-04-2003, 01:58 AM
adrian jaye's Avatar
isnt there a special sealant you need to use that (forgot the proper name) only dries when you reassemle it in the absence of air ?
I'm sure thats what you need to use
The fear of God is the begining of wisdom <><
NotJustPorsche
Subscribe: notjustporsche-subscribe@yahoogroups.com
Old 12-04-2003, 03:09 AM
I'm doing mine for the second time in two years. First time I did it, it leaked in the back. It is a lot of work. Don't know what I did wrong the first time when I did rod bearings two years ago. I hope it'll be obvious when I remove the pan this weekend.
Local non-dealer shop needed 14 hours labor to do it so I'm doing it myself - again.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 12-04-2003, 04:01 AM
todwic's Avatar
I think it was on the PCA site where I read that they put Curel-t or something of that nature on the frond and back of the seal. On my '84 there was a white substance on these areas of my oil pan..
Yeah, after Christmas I'm gonna change the seal on my 951, along with my front end seals. My digital camera sux but I'll take pics anyway. I'm looking for a long assed lead for my web cam. it takes great pics.
'86 951
Old 12-04-2003, 06:18 AM
vott does ziss do?
ronin's Avatar
the Curil T was listed for the oil-cooler seals. I can understand why someone would go the extra step and use it on the pan gasket if it is as prone to leakage as you guys say
Old 12-04-2003, 10:13 AM
I used something similar in the corners last time. It's going to be interesting when I find what I did wrong.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 12-04-2003, 01:21 PM
ae1969's Avatar
Send a message via ICQ to ae1969
Well I am doing my third one...............AND THEY ALL LEAK maybe not right away......
Not at first..........but give it some time. The first 5-10 K miles was great on the first 2 (different cars)..... but then..... rear starts to leak and so does the front.
THIS TIME I AM GOING TO GIVE THE GASKET A BATH IN SEALANT!!!
P.S the pans were square. I think the gasket either gets blown out, breaks down due to heat. Not really sure why. The torque specs are pretty darn low if you ask me......
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 12-04-2003, 02:12 PM
There are two heat shields where the exhaust is near. I've seen others that do not leak. I have access to a machine shop that has one of those huge granite tables that is very flat. I'll take it to work and put it on the table. I did that with a valve cover on another vehicle of mine. We shall see. It comes off this weekend.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 12-04-2003, 02:49 PM
Manute's Avatar
Todwic please, post pics when you have done it,and a simple explanation of the process that a 4 year old can understand,would be highly appreciated.Its the next thing in my wish list.
Thank you big man!
Old 12-05-2003, 01:51 AM
ChrisBennet's Avatar
On the advice of others, I used the Mercedes Surface Sealing stuff. The number on the tube is "A 002 989 73 20 10". It appears to be some sort of RTV.
-Chris
Edit: Found the thread: Oil pan sealant
'80 911 Nogaro blue Phoenix!
'07 BMW 328i Coupe
Old 12-05-2003, 08:00 AM
Mine comes off tomorrow morning. I hope I can see what I did wrong. Mine leaked immediately.
This is Murphy's Law in action. You screw up that which takes you the most time to repair.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 12-05-2003, 03:24 PM
todwic's Avatar
The sealant that was on my '84 motor was white, but I'm not opposed to the black stuff, either. Lawrence, how do you get your oil pan off? Drop the crossmember (pwr st'ring or no?) Do you brace the motor up on the strut towers? Jack it up a tad? I'm wanting to do my rod bearings at the same time, since I got the dammed thing off, or would you just slap the op gasket on w/o taking the o pan off all the way? Do you think loc tite 574 would work for the corners? I still have some of this left from my rebuild.
'86 951
Old 12-05-2003, 09:22 PM
Todwic, pictures coming in a few minutes.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 12-06-2003, 02:01 PM
Supports And Things Removed
This should show what I've removed to get at it. My windage tray is cracked so I have to replace it. It was rather brittle.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 12-06-2003, 02:12 PM
My power steering low pressure line to the cooler is so hard to get off at the cooler that I just cut it with a tubing cutter so no filings remain. I'll install about a 2 inch rubber section. It took me an hour last time to get off at the cooler. Heck with that.
The 2X4 wood is glued together with a good wood glue. Part of the load is on the two chains above; the rest is on the scissor beneath.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 12-06-2003, 02:16 PM
todwic's Avatar
Is that power steering or armstrong? do they both remove basicaly the same? Nice pics. I don't feel so daunted now.
'86 951
Old 12-06-2003, 02:52 PM
