Let's go shooting.
Dark Skies's Avatar
Sway bar end rubbers ...
... are a total bastard to slip on. I couldn't seem to find info on a gentle way of forcing the sods onto the tapered ends - really incredibly tight (even with washing up liquid on them). In the end I had to get a set of mole grips, clamp them onto the beginning of the larger diameter section (to create a ledge), put the rubber (in aluminium bracket) onto the end and then press the bugger on using a bench vice. Is there a better way? Surely that's not how they do them in a Porker workshop?
BTW molegrips (so called because they look like mole traps I suppose) are vice grips over there (pointing roughly in the direction of the Americas).
1983 944 Lux (manual) 2.5 litre 8 valve na and no pas
1991 944 (automatic) 2.7 litre 16 valve na and pas
"I have only five words for you: From my cold, dead hands."
Old 12-04-2003, 04:57 PM
FLA944's Avatar
Send a message via AIM to FLA944 Send a message via Yahoo to FLA944
yessir,
They are a bit of a pain without a press. I have had mine out including the A-brackets for 6 months now and tried pounding with a 4# hammers and no good. Juvy offered the use of his press so when I get the mood and time to start anew I'll give it a shot.
Rick
'83 944 "Guards Red"
New Everything (seems like)
16" 968 Wheels
has never left garage (yet)
Old 12-04-2003, 05:14 PM
TCMdocs944's Avatar
I am not a very small man and I was a pumpin and a sweatin for a good hour when I changed the bushings.
One Ice tea job became a three beer job.
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 12-04-2003, 05:44 PM
Send a message via AIM to TheCooler
Silicone grease and a basketball hoop poll to push it against.
-2002.5 GTI VR6 24V 6SPD
-Kalahari Beige 89 Porsche 944S2
-87 VW GTI 1.8 16v
-2007 Ford PIMP(free)star ...company car....
-1999.5 Jetta VR6
Old 12-05-2003, 09:39 AM
least common denominator
scottmandue's Avatar
There are a variety of sway bar sizes... are you sure you got the correct size bushing? I'm no weight lifter but I was able to install mine with out removing the sway bar by using lots of soap.
2019 Kia Stinger 2.0T
1995 Miata Sold
1984 944 Sold
A lie can travel halfway around the world while the truth is putting on its shoes.
Old 12-05-2003, 12:47 PM
MrPants's Avatar
What is the reason for using soap instead of oil or grease?
84 944 Non Alcoholic
Old 12-05-2003, 12:53 PM
repoman's Avatar
grease is oil based, will attack rubber and even poly over time
'84 944 auto stock
Old 12-05-2003, 01:04 PM
ae1969's Avatar
Send a message via ICQ to ae1969
Yup... its a work out....
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 12-05-2003, 01:07 PM
Send a message via Yahoo to RichMason
I'm replacing all of my front sway bar bushings this weekend. I'm hoping that the cold weather will make it easier (maybe its the other way around?)...
Rich Mason
87 951 for sale $5500
Old 12-05-2003, 01:20 PM
MrPants's Avatar
ahh ok its coming together now, hence why they say to avoid spilling PS fluid on belts etc
RichMason: warm bushing on cold sway bar would provide the most clearence. that makes me think: you could prolly pop these things in a 200F oven to expand them and then slide them on a little easier.
Old 12-05-2003, 03:23 PM
Let's go shooting.
Dark Skies's Avatar
The inner rubbers went on very easily - it was the outers that were tighter than a very tight thing that's tight. Maybe YOU had the wrong outers (although I thought these were the same throughout) as everyone else seems to have had the same trouble.
Old 12-05-2003, 03:47 PM
Let's go shooting.
Dark Skies's Avatar
I'm not sure heating the rubbers is a good idea - it may damage their integrity (the release agent will make the oven smell something cruel too).
When I was struggling to put the rubbers on using brute force it proved so bloody hard (as in not having it at all) that I am convinced I heard a slight clicking noise - it was either a vertebrae or a hernia starting to creak to the max, either way I called it a day. Fcuk that for a game of soldiers!
Once I latched onto locking the grips onto the bar, sticking the rubber on the end and squeezing the whole ensemble (with a drop of Fairy washing up liquid) in a bench vice it actually went on really easily. Just a shame that it took me so long to twig to the idea.
Old 12-05-2003, 03:59 PM
MrPants's Avatar
Originally posted by Dark Skies
I'm not sure heating the rubbers is a good idea -it may damage their integrity.
yea its a gamble. i couldnt find any expansion coefficients or yeild strengths of rubber. they could probably go up to 130F safely since the air gets that hot in some places
Old 12-05-2003, 04:17 PM
speedy007's Avatar
if you cant get them on their the wrong ones. there are 2 or 3 different sizes. porsche special order usually. i went thru all this all ready.
88 944 bastard
Old 12-05-2003, 04:53 PM
Let's go shooting.
Dark Skies's Avatar
It's true that there are a fair few different sizes of sway bar and consequently the inner rubbers (off the hanging brackets) have varying IDs - however I believe that the end rubbers that fit in the aluminium brackets bolted to the control arms are the same size throughout (the end of the bar is machined down quite noticeably). In any event I bought the lot from Porsche using my VIN number and as the inners fitted fine I'm pretty sure they gave me the correct end fittings too. The end rubbers are the ones that do the real work so I'm guessing they need to be pretty damn snug.
http://www.tech-session.com/kb/index.php?page=index_v2&id=23&c=4 )
Old 12-05-2003, 05:05 PM
repoman's Avatar
instead of heating in oven, drop in hot water
'84 944 auto stock
Old 12-06-2003, 01:17 AM
AFJuvat's Avatar
You are correct, the outer bushings are all the same size, the inner ones are different depending on the diameter of the sway bar.
Always had good luck with hot water, soap, or a dab of silicone lubricant to get them on.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 12-06-2003, 07:21 AM
flangermog's Avatar
I phoned my mechanic mate when I did mine and asked if there was an easy way to get those blighters on. There isn't it's just brute force and ignorance.
I found it much easier by jacking up the wheel seperately and lowering the mounting on to the sway bar although when i did it, the jack gave way and the wheel sprung down with the full force of the springs. Fortunately I had just moved my head, which is why I live to tell the tale! Probably not the recommended way to do it but after 2 hours of trying, the jack giving way actually got the thing on there.
If I had to do it again I would employ a Morrissey fan to do it for me....
(x)'89 944 S2 Cabriolet (Guards Orange) :
( )'90 944 S2 (Maraschino Dead!) :
( )'89 Audi 90 Quattro 2.3 20V :
( )'92 Renault Clio 1.4 :
Old 12-08-2003, 02:54 AM
A morrissey fan? Sounds vaguely pejorative. Watch out there are still a few of us out here . Seriously though, this seems like a UK thing. My sway bar end pieces went on in seconds with some silicone - just spun them around and around while pushing them in. Maybe the later cars are different or I just have copius amounts of leaking fluids on my bar! I'll count myself lucky and know that there will days that will not go so smoothly.
Cheers!
Rich Mason
Old 12-08-2003, 06:49 AM
Let's go shooting.
Dark Skies's Avatar
Sounds like you're into the whole Morrisey suicidal kick to me!
It's easier to just remove the whole bar and put the rubbers on at the workbench. In the end I found my workaround (using the vice as a makeshift press) the best apporoach - went on very easily once I'd twigged. By the way, the best way to do this in future is to have the front wheels on ramps rather than jacked up (on AXLE STANDS). That way the control arms are pre-loaded for the correct positioning of the sway bar rubbers when the bar mountings are tightened.
Old 12-08-2003, 07:23 AM
