Question Wheels and tires.
I have a 1984 - 944, with the porsche five spoke wheels that were typically seen on the 911's. I think they are referred to as fush type, but I am not sure. The fronts are 7 x15 with 215/60 tires. The rears are 8x15 with 215/60 tires. My question is can anyone tell be how large (width) a tire I can mount on the 8x15 wheels on the rear without causing a problem, such as the tires rumbing an interior body part or suspension frame, etc. I am guessing a 235/50 but I am not sure.
Thank you
Paul
Old 12-06-2003, 10:17 AM
Verruckt's Avatar
225/50R15 will fit your car, but you will have a little speedo error. Check out www.tirerack.com for different tire options. I don't thing your going to find a 235/50 tire, or even a 245/45R15 tire for your car. You can fit up to a 245 tire with an eight inch rim, however there are few high performance tire options nowadays for 15 inch rims.
The crashes people remember, but drivers remember the near misses. Mario Andretti
1991 944S2 Rally #951 Rally-America.com
Old 12-07-2003, 12:44 AM
andrewgoh's Avatar
I hope this will be useful:
Just found out today a nail took quite a liking to the rear tire of 84 944 NA. It's a good time to change my 4 tires anyway
I am currently running a 215/60R15 front and rear set-up (= 129" sidewall height). The current tires make the car stand too high for my liking. I am changing to 225/50R15 ( = 112.5" sidewall height)
front and rear.
I considered the Kumhos ECSTA 711 ($51) or Yokohama AVS ES100 ($77). I eventually chose the Kumhos from Tirerack.com:
225/50HR-15 Kumho ECSTA 711 $51.00 each
Tire road hazard program $6.12 each
Shipping $60
Total: $296.30
(Tire installation, balance and disposal not included. Another $100 approximate)
Old 12-07-2003, 01:33 AM
meister member
speedracing944's Avatar
Aren't H rated tires only good for 130mph? I though V rated were the lowest rated tire to put on.
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 12-07-2003, 06:55 AM
andrewgoh's Avatar
I will not be using the tires on my 944 NA for Auto-crossing or track....the H rated should be fine.
I have ZR rated tires on my 951.
Old 12-07-2003, 05:15 PM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
i personally would go for the 225/60s... i like that fat sidewall. gives the car that "vintage racecar" look (think 1960s ferraris)
Current Stable: Black 07 Porsche Cayman S: FabSpeed Maxflo Exhaust; VividRacing ECU Tune; IPD Competition Plenum; 997GT3 Throttle Body; De-Snork'd.2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Silver 09 Mini Cooper S ("Mighty Mouse"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944. Green 97 Volvo 850 Wagon ("The Viridian Falcon").
Old 12-08-2003, 07:46 AM
andrewgoh's Avatar
Here are the existing 215/60R15s on my 944 NA:
http://www.globewerks.net/personal_images/2002august_porsche944/DSCF0200.JPG
The 225/60R15s will look somewhat similar to the tires in the pic (with a slightly larger sidewall section)
Old 12-08-2003, 10:45 AM
Writer/Teacher
CJFusco's Avatar
yessir, i have the 215/60s now, but i am getting close to needing new wheels. Since the '44 is getting "limited use" in the winter (see new sig), I figure it will be time for new tires in the spring. I am definitely getting 225/60/15s, with V-rated or higher.
Old 12-08-2003, 04:28 PM
