Post Fix those power seats...
Gentlemen,
If you have a bad switch or switchs on you power seats, loosen the swith housing and shake it hard. If it rattles then you just found the problem. There are little ball bearings that sit atop springs in these, one of mine came out of its spring. I think you will have to remove the seat, then take apart the switch. Mine did not have a lot of wire, so its kinda tight to work on. There is some grease inside the switch, I stuck a glob on both springs, balanced the balls on top and put it back together. Works like a charm.
Sergio.
Old 08-09-2001, 04:58 PM
