Don 944 LA's Avatar
Mr. Moly lubricants ... Need advice of Y'all
It has been recommended that the only safe oil additive is molybdenum disulfide .
Mr. Moly has many products.
I am going to get the Oil additive.
My question is :
Has anyone also used the Transmission (ATF) additive in the power steering pump ???.
Has anyone used the Gear Oil additive in the Manual transmission ???.
Or does anyone have any opinions of the products that they carry.
Thanks again for your input
Don
1984/85 944na
Gold exterior / Black interior
Los Angeles / San Diego
Lookin for ideas etc...
Old 12-13-2003, 02:24 PM
AFJuvat's Avatar
Hi Don,
Moly is a high pressure-hi temp lubricant - normally used in wheel bearings and the like - also a main ingrediant in assembly lube - which is what lubricates the car for the first 15 seconds or so until the oil starts flowing, after which, it is washed away by the oil.
There are no oil additives recommended nor should they be necessary - there are many studies out there that show the additives do more harm than good (Slick 50 immediately comes to mind).
Summarized below, but in short, you get what you pay for. The money you spend on mediocre oil and an additive is usually more than what you would spend a a good quality oil.
If you use a good quality oil or a synthetic and stick to the oil change schedule (3000 miles for regular oil, recommend 5000 - 7500 miles for synthetic), you will not have any wear problems. Recommend Mobil-1 for synthetic and Valvoline for regular oil.
Same applies to transmission fluid. Mobil-1, Swepco 201, and Valvoline are excellent lubricants. You want a gear oil in the range of 75W90.
There should be no need for ATF additives in the power steering system. the PS system uses ATF for its excellent hydraulic and lubricating properties - considering the relatively low levels of friction internal to the PS system, that should be more than adequate for your needs.
The only additive ever recommended by the factory is Chevron TECHRON to keep the fuel injectors clean.
Any "Stop leak" product is definately not recommended.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 12-14-2003, 11:50 AM
dj_yen's Avatar
Listen to AFJuvat
best thing to do is to change your all your lubricants as scheduled and according to your mileage/driving style
if you want better protection, change it more often
944 NA 5-spd, Red, 1987 - 2005
May She Rest in Peace
944 Turbo 5-spd, Black, 1987-present
70k miles
Old 12-14-2003, 05:57 PM
FLA944's Avatar
Send a message via AIM to FLA944 Send a message via Yahoo to FLA944
Listen to Mother Juvy!
Under no circumstances use any additives for any application.
A good synthetic oil is perfect. I like Mobil 1 but, all vendors have the same make-up.
'83 944 "Guards Red"
New Everything (seems like)
16" 968 Wheels
has never left garage (yet)
Old 12-14-2003, 06:12 PM
Don 944 LA's Avatar
Thanks a bunch for your input guys...
I was planning on Mobile 1 and changeing all other fluids as well ( tranny, Diff etc.. ), I just thought that molibdimum would have added some additional stuff.
Don
1984/85 944na
Old 12-14-2003, 06:16 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
Don
Are you a politian? I would like to include everything that was included.
Things that bunch or clog can seldom help. Slick 50, some other stuff, and similar can clog the oil ports and stuff because they are long strings of stuff. Moly may be different, maybe not: I'm not a freakin chemist. Mobil1 is good stuff, and that's good enough for me. Why reinvent the spoon?
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 12-14-2003, 07:34 PM
