Hey, my car is great on the highway. Just as smooth as any other car ever made. However, when I stop, the steering wheel has this little throb or pulse in it. It feels like the brakes. Anyone know what is goigng on?
Your rotors could be warped.
sounds to me like you have a warped rotor
My steering wheel doesn't vibrate or anything but turns to a side sometimes. If i have it a little off center it will turn to that side, is that normal?
sounds like you might need an alighnment, should track straight
Where can I get rotors, and what do they cost?
The negative scrub radius built into these cars front suspension geometry will cause uneven 'feel' if the ground is not level (it'll pull to the lower side). On the positive side, the cars' are a bit more predictable at/near the limit, and tend to track straigt under hard braking when the traction between the left and the right sides of the car are different.
Ahmet ------------------ It's all the driver... My page over1g@hotmail.com Porsche owners Gallery.../My 944 |
You can get rotors from any number of places such as Pelican Part, Vertex, Autotechnics, etc.
