Ok, random problem....one day it started sounding raspy when i started it and by 7pm that night i couldnt' start the car. I jumped it and it started fine, but the battery is fairly new. So i checked the alternator by taking the positive off the battery while the car was running, it kept running so the alternator works.
What could it be? Thanks |
Even if the alternator 'works', it needs to be regulated and produces enough juice to recharge the battery as well as run the rest of the car ... check with a voltmeter at the battery, should be around 12.5 when car is off, and 14.0 when idling ...
E |
Did you remove the cable from the battery while the car was running? I have heard that doing that will damage the alternator.
/Magnus |
yes while the car was running.....and it shouldn't be bad for the alternator. I took the battery off and took it to autozone and they tested it and said it was bad. I bought a new one and the car started fine. When the car is off the voltage on the gauge is 12, and when idleing its at about 13. I dont know hwo accurate the gauge is but should it read higher than 13?
