STP oil filter
is there any reason i should not be using the STP "85 porsche 944" oil filter for my car?
'82 928S ![]() '85.0 944 Not Awesome - Being Parted Out
The oem or mahle filters are supposed to leave a bit of oil "in the can" which circulates during start-up....I believe.
Just read a web article that basically says cheap oil filters are just that...cheap. I use those $3.00 filters for quick run throughs to clean it out after repairs, only then change it for the better one when I put in the real oil. I am doing my front seals this weekend and since I will now be leak-free I am switching to Mobil 1 ---15/50. Splurge a little... Use Mahle or, I have heard the Mobil 1 filter is not bad either.
83 944 white w/Boxster wheels Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Bosch filters should be good, no? That's what I use...
83 944 N/A 5 sp. (mine) 90 Acura Integra auto (sons) 2000 Honda Odyssey EX auto (wife) 83 Suzuki LT 125 (4 wheeler) (wife) 92 Honda XR 80 (son) 97 Honda CR 125R (son) 98 Honda CR250R (MINE) 2000 Kawasaki KX 65 (son) 2003 Honda XR 50 (Son and daughter) |
Yeah. Bosch filters.
I use the MAHLE spark plugs.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
Factory filters
As I stated in another post, factory oil filters are the best available for your 944/T. Many people do not know that the pressure relief valve and spring are specially designed for your engine. This particular design is not always replicated in aftermarket filters. Mahle filters come in as a close second, however I would not use any other brand. Other filters can cause oil pressure fluctuations, there is an old TSB regarding this information. Remember, Porsche oil filters can be purchased elsewhere in large quantites at a discount, check the back of Panorama for participating suppliers who have specials on factory parts.
Even though I drove a GT2, I still love my 944. |
Napa also sells one that has the valve in it.
86 944 daughters 88 944 step-sons 07 Ranger 4x4 I have tons of spare parts, let me know what you need. |
What brand filter is this? NAPA?
SoCal - your killin me LOL
Hey, I THOUGHT that was a joke, but the germans....You just never know.....
All of the off the shelf oil filters that I have seen have at the auto parts stores have rust in them. The whole idea is to get little parts of metal out of the engine oil, not put more metal parts in. Buy a ten pack of oil filters from Zims for next to nothing, so you don't have to even worry about back flow valves and rust. I bought a NAPA filter once in a crunch. It cost a lot! I could have gotten 4 filters froms Zims...
The crashes people remember, but drivers remember the near misses. – Mario Andretti 1991 944S2 Rally #951 Rally-America.com |
Re: STP oil filter
With all the so called "marketing" STP has done over the years, I'd wonder if it was just some generic filter out there that they smacked their "STP" name on. I'd ask, "is there any reason to use a STP filter". I would stick with the stock type OEM filters that have the built in check valve system, especially because the 944 has an upside down filter that would otherwise drain out thereby allowing for a dry start every time. You want oil to be in the filter when you hit the ignition, and the check valve will make sure this happens. P
1983 928S 5-speed, 1984 944, 1990 944S2 Cabriolet My other car is a Chris Craft Commander http://www.chriscraftcommander.com |
well... i'm using the STP filter right now. is there any way to tell if i'm "dry starting"? does Zims have a website?
a "dry-start" will (probably) show up on the oil pressure gauge. Instead of seeing the gauge jump up into position, you may see a moment of no pressure before it registers, that just my hunch.
I know there are cheaper filters out there, but I'd stay with the OEM type. P
well, i didn't look REALLY hard, and i wanted to hurry up and do an oil change, because it was imminent.
