A/C Problem
My a/c blows coolish air, but the car never gets cooler, the 100 Degree Heat outside just matches the cooling effect of my A/C. It blows hard and all. Could it just need some Freon or something?"
Could just have a slow leak. Bu you may need an expansion valve or a new dryer. Sometimes they get blocked and gumed up and flow is restricted. If it's still coming on you probably in good shape! I had to replace almost the entire system in mine. Look for bubbles in the dryer sight glass they are a sign of a low charge.
| All times are GMT -8. The time now is 07:41 PM. |
