Send a message via AIM to shocker1322
924S suspension tuning
How can the rear of the 944/924S be stiffened up? I have had problems with so much body roll the fender will rub on the tires. Normaly people would say just put in stiffer springs, but Germans seem to avoid them.
Does anyone know who sells a Neoprene bushing kit? I have been unable to find anyone who does.
Are adjustable coil-overs for the front available? And how about anti-sway bar upgrades. I have heard the M30 and M28 from the 968 (I think) are the biggest available. Do they make any larger ones or nicer/adjustable ones?
Old 12-19-2003, 09:26 AM
JH924S's Avatar
Send a message via AIM to JH924S
As far as the sway bars go the m030 have 3 different settings, stiff stiffer stiffest. I have a pair of turbo sways front and rear for sale if you want em. just the bars no bushings or droplinks
1987 924S black on black , does it get any better?
Old 12-19-2003, 09:42 AM
SoCal Driver's Avatar
Check which shocks you have. The Koni's can be set for rebound/stiffness. There are options to remove the torsion bars and use coil overs on the rear.
Still between a stronger sway bar and proper shocks you will find the back quite tight.
P.S. Some body roll is expected. It's part of the design. But then may like the go-kart feel.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 12-19-2003, 10:13 AM
Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
Rear bar will help a bit but to do it right change the torsion bars to 29mm-30mm. M030 968 Sway bars are your best bet if you have the cash.
It depends on the use you have with the car. Racing, AutoX? What group, SCCA-PCA would you run in? This matters when it comes to removing the torsion bars and use coil overs.
Budget set up go with a Koni shock, Turbo bars and helpers springs.
Yes there are front coil overs available at www.944Racing.com or www.paragonproducts.com
You want the front ride height adjustable coil over kit.
Paragon has the bushings you need also.
Hope this helps! Sman
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 12-19-2003, 12:24 PM
