Question ???Rough Start???
Tell me if any of you guys have ever expierenced this. In the mornings, whenever I start my '83 944 it turns on without a hitch. However, when I try starting my car after it sat in the sun all day it struggles to turn on. I live in Riverside, Ca and it can get pretty warm during the day (100+) but I thought it was supposed to be the other way around.
"I'll always be #1 to myself"
Old 08-17-2001, 08:44 AM
Banned
Post
its a faulty check valve in your fuel pump.. time for a new pump..
when your car is sitting after being hot, air gets let into the lines of the fuel pump. so when you start, instead of getting gas, you are gettin air.
SHAUN
Old 08-17-2001, 11:58 AM
Banned
Post
Hey Mideast. good answer to a technical question. Ya get 1 point
Old 08-17-2001, 12:01 PM
Banned
Post
eat a d*ck
Old 08-17-2001, 12:04 PM
Banned
Post
Sahun, you would do a lot better on the board if you would leave your bad attitude at the door. Angst get's you nothing.
[This message has been edited by p0r2chby (edited 08-17-2001).]
Old 08-17-2001, 12:05 PM
Post
Well, you DID provoke him.
Old 08-17-2001, 01:30 PM
Wink
hey shaun,
if it's a faulty check valve, can't i just replace the valve and not the whole pump. $15 compared to $215.
thanks.
Old 08-17-2001, 05:02 PM
Post
The check valve is INSIDE the fuel pump. The fuel pump is not made to be dissasembled. I doubt very much if you could get the check valve by itself.
But if you do find a check valve repair kit, let us know
Mike
Old 08-17-2001, 07:31 PM
Post
i just had a hot start problem and fixed it by taking off the ground strap, cleaning the mount for it on the firewall and reinstalling. i also used a Massive Overkill groundstrap. wont work for everyone but a cheap place to start. fuel filter is worth looking at also, anything that wwould prevent fuel from reaching injectors.
Old 08-18-2001, 09:29 AM
Post
Hey mike944,
I found that pelican is selling a check valve for 15 dollars. Are they reffering to a different valve? Follow the link.
http://www.pelicanparts.com/catalog/shopcart/944M/por_944M_fuelij_main.htm
Old 08-18-2001, 04:59 PM
Post
I have no idea whether this is the same valve. Call someone at pelican and ask them.
Old 08-19-2001, 08:02 AM
