paulc's Avatar
clicking noise in neutral
slight gear-related sound, like a clicking, when in neutral with foot off of the clutch and brake....when either is slightly applied it stops......any ideas?
87na guards red(mine)
98 suburban(mine)
04 4Runner(wife's)
Old 12-26-2003, 02:05 PM
SoCal Driver's Avatar
The common link between the brake and clutch is the hydraulic reservoir and the mounting bracket under the dash.
The throw out bearing is about the only thing that would make a slight high pitched rhythmic sound with no pressure on the clutch.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 12-26-2003, 02:33 PM
paulc's Avatar
thanks SoCal, will check it out
98 suburban(mine)
04 4Runner(wife's)
Old 12-27-2003, 05:01 AM
I still can't see any connection between the TO bearing and the brake pedal.
Old 12-27-2003, 06:29 AM
paulc's Avatar
the noise does seem like it is coming from under the passenger side dash. i tried rolling at about 5mph in neutral without touching the pedals and i couldn't hear anything, only when wheels are stationary
98 suburban(mine)
04 4Runner(wife's)
Old 12-27-2003, 07:44 AM
