EGSMachine's Avatar
Post 951Carter accusump
your link to your club page didn't work.
http://myclubs.excite.com/myclubs/browse?cid=.ls4r1n5R3iJ
anywhere else the kit is available?
e
84-9445m
Porsche, "Overtly Masculine Feel".
Old 08-16-2001, 07:26 PM
EGSMachine's Avatar
Post
just trying to keep it at the top so he can see it.
e
84-9445m
Old 08-17-2001, 03:34 PM
951carter's Avatar
Post
excite has closed. i can send you some pics if interested. i am going to get some up on the web soon but have been short on time lately.
Old 08-17-2001, 08:32 PM
951carter's Avatar
Post
actually, here are some
tis is the accusump in the wheel well. the liner goes back in to protect it.
[img]pics.http://communities.msn.com/_Secure/0LgAgVJ8OP0A4UK6TebsSvYHNTQq5FLYj*isDvKBoyrAHVyBqk EJvdOHNw!zaObYoocchomJXfuQ/dsc00002.jpg[/img]
this is the oil filter that connects a line to the accusump. they are great filters that filter to 8 microns which is much better than stock and makes filter changes a breeze. the inserts are $10 a piece and last 3x longer than the stock ones
[img]http://communities.msn.com/_Secure/0LwAgAM8O3kk4UK6TebsSvQ7m3OGIOssplhG4de!7GtX88cB*I TZYYvq6Uo!wd7wxCaJ0R78Fii0/dsc000011.jpg[/img]
the accusump delivers oil pressure when the ignition is switched that cures the dry-start problem and will keep oil pressure even if the oil pickup goes dry, which is the cause for bearing failure in 944's.
Old 08-17-2001, 08:41 PM
951carter's Avatar
Post
hmmm....i'll try again
[img]http://communities.msn.com/_Secure/0LgAlAJ8OP0A4UK6TebsSvYHNTQq5FLYj*isDvKBoyrAHVyBqk EJvdOHNw!zaObYoocchomJXfuQ/dsc00002.jpg[/img]
Old 08-17-2001, 08:42 PM
951carter's Avatar
Post
the scratches on the fender are from the track, not the accusump install :^)
Old 08-17-2001, 08:44 PM
EGSMachine's Avatar
Post
Thanks,
I saw all those pics from your earlier post, now i am interested in buying the kit. so we can do it between us or whatever you want.
Let me know,
E
84-9445m
Old 08-18-2001, 08:26 AM
951carter's Avatar
Post
drop me an e-mail and i will get you more info. i can be reached at p.porsche@verizon.net
Old 08-18-2001, 09:26 AM
Post
What are you running, a 2 qt. or 3 qt. accusump?
Old 08-18-2001, 05:39 PM
EGSMachine's Avatar
Post
looks like the 3 quart to me, as i would also like, but i also think 2 would suffice.
84-9445m
[This message has been edited by EGSMachine (edited 08-19-2001).]
Old 08-19-2001, 10:33 AM
Post
I know of two 944 turbos that were equipped with the Accusumps. Both spun bearings anyway. Both were track cars.
[This message has been edited by Lawrence Coppari (edited 08-19-2001).]
Old 08-19-2001, 11:54 AM
951carter's Avatar
Post
it is a 3 quart. an accusump cannot fix previous damage. it will also not help if you run the car out of oil. if you study how one works you will see that it WILL prevent loss of oil pressure if the pickup is uncovered, which is why 944's spin rod bearings. now if you have already damaged your bearings and install an accusump, it will NOT help. in fact you will effectively ruin the accusump also with the metal shavings. I am not trying to push these on anyone, in fact there is little to nothing in it for me. we put together a nice clean installation of the kit that can be bolted on. we buy the parts wholesale and sell them retail. we did this because we have seen so many poor accusump setups on other track cars. you would not believe some of the places people put these things. bottom line, look at the facts, how it works, and you will see why it works. we have a bucket of spun bearings at the shop, and not one of them came from a car with an accusump.
Old 08-19-2001, 03:12 PM
Post
951carter how much for your setup, or if you don't want to post $ I can e-mail you?
How is your kit plumed? Does it go:
Engine->adapter plate--->remote filter--->accusump--->adapter plate->engine???????
I have an external oil cooler that I also want to install, where in the system would it go? Thanks.
Old 08-19-2001, 07:33 PM
951carter's Avatar
Post
sorry guys, i completely spaced on getting the info together today. i will do it tomorrow. i do not mind posting $ but i have to get it together. it goes from the spin on filter directly to the accusump, no adaptor. if you want to run an external oil cooler on an n/a i would suggest fitting the unit from the turbo.
Old 08-20-2001, 07:23 PM
