Goku's Avatar
Post Overheating
Well my car has been getting up to 3/4 heat lately. With my AC on and 100°+ outside. My pumps are working and i have coolent/water. I am looking to buy water wetter. Is there anything I should be looking at? Last summer in heat (less than this) i was staying at 1/4 with the AC on.
ßrªÐL£µ
88' 951
2k VW Golf 1.8L TURBO
Reluctantly crouched at the starting line...
Old 08-21-2001, 09:16 AM
Banned
Post
when was the last time you did a c-system flush?
The ac condensor sits in front of the radiator. (A trubo, like your has even more stuff up front that I am not familiar with.) Both the radiator and condensor are prone to collecting a lot of bugs and other misc debri. Have you done a good pressure type wash to make sure the vanes are clear.
Old 08-21-2001, 09:41 AM
Goku's Avatar
Post
I havn't done a flush or a pressure wash in a while. What do you mean by doing a pressure wash? Like those pay ones and just spray the crap outta the front of the car?
ßrªÐL£µ
88' 951
Old 08-21-2001, 10:01 AM
ruechaos's Avatar
Post
Check to see if your cooling fans are kicking on. A connection came loose on my n/a and it was constantly getting too warm.
-Tony
Old 08-21-2001, 10:02 AM
Goku's Avatar
Post
My fans seem to be working. Just replaced the fan switch not to long ago.
Old 08-21-2001, 10:04 AM
Banned
Post
Depending on the machine, that might be too much pressure and may damage things. I'm thinking about the pressure wand at a coin op car wash. Spray it thru the front opening or from the back side. Should do a good job of removing any bug/gunk buildup and thus allow more air thru. I would also do a good system flush. This may not be the fix but it's worth a try.
Old 08-21-2001, 10:06 AM
Goku's Avatar
Post
OK sounds good the car needs a good wash anyways =) It has a bra on it now. So i need to open the hood and spray twords the front or from under the front bumper tword the front?
Old 08-21-2001, 10:09 AM
Send a message via ICQ to PrerYDoG
Post
Then I wouldn't worry too much about it, mine does the same thing. Long as it doesn't go up and hit redline. If it gets up to the 3/4 and then comes back down to the 1/2, then you're probably safe.
But take a look from the front. When you look between the slots up front, you see the AC condenser...the fins on all mine are pushed over and mashed (the cost of hitting bugs at 100). Anyone know how hard it is to replace the A/C Condenser??
Goku - it's also a possibility that your radiator needs to be replaced. They do get corroded and after time, just don't function like they used to.
Mark
Question
The 944 radiator will clog up if it isn't maintained. To test if your rad is clogged, run the engine until it's hot then turn it off. CAREFULLY disconnect the fan electric plugs. Now you can feel the radiator. If any part of it feels cool to the touch, you are probably not getting hot coolant to that part and that section is clogged. Changing the radiator is relatively easy. Just remember to remove the top radiator mounts before you remove the bottom mounts and slide the old radiator out.
Old 08-21-2001, 04:39 PM
Obin Robinson's Avatar
Wink
http://obin_jess.tripod.com/Porsche/overheating.html
works 100%
good luck!
obin
Old 08-21-2001, 05:55 PM
Dave951M's Avatar
Post
"But take a look from the front. When you look between the slots up front, you see the AC condenser...the fins on all mine are pushed over and mashed (the cost of hitting bugs at 100). Anyone know how hard it is to replace the A/C Condenser??"
That's an easy fix. There is a tool called a radiator comb, it's made in several spacings for different radiators and condensors. Just go down to a shop that has body working tools available and ask for one. They're only about $15 and last forever. It functions just like a comb, just takes a while depending on how many bugs died a sudden kinetic death.
Dave951M
[This message has been edited by Dave951M (edited 08-21-2001).]
Old 08-21-2001, 06:14 PM
