-   -   Headlight problem - 1983 944 (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/141519-headlight-problem-1983-944-a.html)
Stanton Horne 12-29-2003 08:17 AM
Low beam on left side does not work. I have swapped all 4 fuses
and replaced headlight. Anybody got any ideas on where I can look now? Do the wires go to each side(driver and passenger) independently of each other? Thanks for any suggestions.
Chris_924s 12-29-2003 08:32 AM
Check out the grounds behind the headlight bucket- it's a bundle of brown wires with terminal lugs - clean them off and see if it gets better..
Britwrench 12-29-2003 08:47 AM
Did you check the bulb (or sealed beam). The first thing to do is check for 12v and ground at the headlamp. It may be the bulb or a brokem wire in the harness right by the headlamp.
Stanton Horne 12-29-2003 09:47 AM
I put new 'Sealed beam' in and had the same problem, I switched Left side with Right side. There are 3 wires going into bulb - on bight, I get voltage on Low Beam, I get no Voltage. Do I trace wire to other side or does wire to the fuse box?
